Author Topic: Cherry plate mount stabilizers  (Read 2224 times)
Offline kgolden
« on: Wed, 07 March 2018, 21:06:12 »
Does anyone know the part number for Cherry plate mounted 6.25U stabilizers so I can order some from Mouser? thanks in advance
Re: Cherry plate mount stabilizers
« Reply #1 on: Wed, 07 March 2018, 21:18:56 »
No distributor has them in stock with 6.25u wires, as far as I can tell. I just checked a few days ago. Lead time is like 12-22 weeks, and MOQ is like 1000+ units.
Your best bet is honestly 1upkeyboards.com, zealpc.net, or techkeys.us probably.
Offline kgolden
« Reply #2 on: Wed, 07 March 2018, 21:25:55 »
12 to 22 weeks!? Wow. I ordered a few sets weeks ago from winnja... haven't seen them yet. Not that I "need" them just have a few boards that will need them sooner rather then later. Do you know why there is a shortage of 6.25 wires?
Edit:... I found some and ordered. Thanks
« Last Edit: Wed, 07 March 2018, 21:36:45 by kgolden »
« Reply #3 on: Wed, 07 March 2018, 21:37:28 »
Glad you found them! All I saw was 8-unit wires in stock at the major suppliers.
