Author Topic: [IC] MEME | Gasket-Mount 65% (Dead 5/10/2018)  (Read 78558 times)
Offline p_blaze
Re: [IC] MEME | Gasket-Mount 65%
« Reply #50 on: Fri, 09 March 2018, 16:57:49 »
Well, I've happened upon a first crossroad. Having never run a keyboard group buy before, I honestly don't know which type of screw is more popular in the community!
Hex or Phillips?
Aesthetic: hex, slot, phillips
Function: slot, phillips, hex
If it strips, good luck getting a hex out easily :'( :'(
I've certainly been there...
Would using different screw heads for different places (like, slot for the badge and hex/phillips for the main body) be a good idea?
Personally I prefer hex. However i like having matching sizes throughout which can be tricky using hex. I think Phillips is possibly the best in that regard, especially since you don’t really need to crank down on them in this sort of application.
Hex or Phillips?
hex > all
I think I'll use a slot for the badge, as that'll be removed much more often and has a higher chance of stripping. Plus, you'll never see it anyways. Hex for the rest, though.
I already have a spot right??? 🤔
🤔 There are no spots in this raffle.
Would the board come with both a blank and a MEME badge? Or would we have to purchase both (If that's an option)?
You will receive both, but alternative colors will have to be purchased.
+1 I've seen too many hex bolts stripped
Offline Purp
  • the colour, not the weed
« Reply #51 on: Fri, 09 March 2018, 16:59:25 »
Not sure if it was asked previously, but will we be able to get the blank plaques engraved from you instead of blanks?
Offline pr0ximity
« Reply #52 on: Fri, 09 March 2018, 17:30:22 »
Very najs. Why gaskets on the top as opposed to the bottom of the plate? I've wondered if it would change how it feels, potentially a little softer? Though that might depend a bit on how tight if a fit it is.
If the gasket is on the bottom then it can be compressed which could produce some awful sounds since the plate could start tapping on the top case.
While that would make sense for a very soft gasket, I don't think im practice it would be very likely. The gaskets on the Keycult are quite compressed already, and the gasket on the 356mini (which is under the plate) is much thicker and softer yet it does not chatter at all.
Offline Krelbit
  • Switchmod.net
    • Switchmod
« Reply #53 on: Sat, 10 March 2018, 11:31:27 »
Hex or Phillips?
Hex or Phillips?
hex > all
I've been there, man.
Super hyped for this board that top bezel tickles my fancy, I love it.  :thumb:
Sadly not. Text is cnc'd.
Offline pixelpusher
« Reply #54 on: Sat, 10 March 2018, 13:18:46 »
You could have them engraved somewhere local, but of course it would be raw aluminum where it was engraved, since it would go through the anodized color.  Still could look cool though, if you're really wanting it personalized.
Offline Kafka
  • i like clean things
« Reply #55 on: Sat, 10 March 2018, 18:22:33 »
I've stripped too many hex screws to trust them.
Offline Krelbit
  • Switchmod.net
    • Switchmod
« Reply #56 on: Sat, 10 March 2018, 19:41:03 »
If enough interest is there, I could possibly offer a seperate set of screws with a different heads.
Offline ramnes
  • T fou, mec?
« Reply #57 on: Sat, 10 March 2018, 20:47:59 »
Nice. Want 60%. Not sure about having "meme" written on the top of my board tho.
Offline amnesia0287
  • Formerly Amnesia
« Reply #58 on: Sat, 10 March 2018, 22:47:37 »
Stop using the wrong key.
Offline Krelbit
  • Switchmod.net
    • Switchmod
« Reply #59 on: Sun, 11 March 2018, 00:20:06 »
Unless this goes absolutely perfectly and I come out of the buy 100% wanting to do more keyboards another board is out of the option.
There are blank badges for those who aren't a fan of the meme badge.
Offline blacksimon
  • illuminati.works
    • illuminati.works
« Reply #60 on: Sun, 11 March 2018, 00:21:50 »
This looks great, I wish you looked this good bby
Offline Krelbit
  • Switchmod.net
    • Switchmod
Re: [IC] MEME | Gasket-Mount 65% (Small update)
« Reply #61 on: Sun, 11 March 2018, 09:19:00 »
Update made to OP. Will comment here as well.
Update 1: Currently working with the elastomer company, and will have gaskets finalized by 3/12/18 or 3/13/18. Color choices came in, and I have asked for anodization color chips. The choices for color are:
  • Silver
  • Violet
  • Red
  • Brown
  • Green
  • Black
  • Orange
  • Gold
  • Blue
  • Olive Drab
  • Yellow
There are 11 Colors here, and I'd like to chop it down to 7. After I get the color chips, I will hold a vote for colors.
I've added a couple items to the to-do list pertaining to these matters.
Thank you for your continued interest in my project.
« Last Edit: Sun, 11 March 2018, 09:26:08 by Krelbit »
Offline xondat
  • i'm not a star
Re: [IC] MEME | Gasket-Mount 65% (Small update 3/11/2018)
« Reply #62 on: Sun, 11 March 2018, 09:59:15 »
Pink please :'(
Offline Marutks
« Reply #63 on: Sun, 11 March 2018, 11:27:17 »
what is gasket mount?   is it better than top mount?
Offline xondat
  • i'm not a star
« Reply #64 on: Sun, 11 March 2018, 11:55:40 »
The top and bottom piece clamp the plate in between, and where the plate touches them, there is Silicone. Not better, just different.
Offline Rob27shred
  • Insane in the Membrane! 👻
« Reply #65 on: Sun, 11 March 2018, 13:01:36 »
Truth, LOL! Hex screws can be frustrating when you don't have the proper size key, but considering they are so common with kits I'd recommend investing in a decent set of hex keys that has all the common metric & SAE sizes. Something like this, https://www.homedepot.com/p/Husky-SAE-Metric-Long-Arm-Hex-Key-Set-26-Piece-HLAHKSM26PC/202934869
Offline Krelbit
  • Switchmod.net
    • Switchmod
« Reply #66 on: Sun, 11 March 2018, 16:02:39 »
Do boards usually include their own hex screw? If so I'd like to hop on that as well.
Pink please :'(
no thnx xoxo
« Reply #67 on: Sun, 11 March 2018, 16:04:57 »
Pink please :'(
no thnx xoxo
my weaven had a hex tool, my mira didn't
Offline HardcoreDesk
« Reply #68 on: Sun, 11 March 2018, 19:46:11 »
Not sure if this has been asked already, but what's the chance of getting customized nametags? If not, then do you have any estimate of what it might cost for an individual to get the blank tag engraved?
Offline Krelbit
  • Switchmod.net
    • Switchmod
« Reply #69 on: Sun, 11 March 2018, 21:59:00 »
Not sure if this has been asked already, but what's the chance of getting customized? If not, then do you have any estimate of what it might cost for an individual to get the blank tag engraved?
Very low chance of customized badges. The text is cnc'd on.
No idea about engraving costs.
« Last Edit: Tue, 05 June 2018, 21:50:35 by Krelbit »
Offline MajorclaM
« Reply #70 on: Mon, 12 March 2018, 00:10:53 »
Would you be opposed to releasing a template for the badge in case people wanted to make custom badges by 3d printing or otherwise?
Offline crtexcnndrm99
  • *profile image used without permission* ;)
« Reply #71 on: Mon, 12 March 2018, 02:26:37 »
Brown/beige (read: beige) would be amazing ;)
You're a smooth smoothie, you know? ~ Gaear Grimsrud
Offline Krelbit
  • Switchmod.net
    • Switchmod
« Reply #72 on: Mon, 12 March 2018, 08:47:52 »
I hadn't actually thought of that. Sure, I'll release the files after the buy is done.
Offline dubious
  • 쏘쿨
« Reply #73 on: Mon, 12 March 2018, 12:35:07 »
good **** go౦ԁ ****👌 thats ✔ some good👌👌**** right👌👌there👌👌👌
Offline Krelbit
  • Switchmod.net
    • Switchmod
« Reply #74 on: Tue, 13 March 2018, 14:14:39 »
Update 2 - 3/13/2018: Prototype PCBs have been ordered! They will be in my hands hopefully by the month's end.
« Last Edit: Tue, 13 March 2018, 14:16:58 by Krelbit »
Offline Cavemann6
« Reply #75 on: Wed, 14 March 2018, 21:30:24 »
 :thumb:
Offline Krelbit
  • Switchmod.net
    • Switchmod
Re: [IC] MEME | Gasket-Mount 65% (Miniscule update 3/13/2018)
« Reply #76 on: Fri, 23 March 2018, 14:15:54 »
Update 3 - 3/23/2018
Prototype PCBs have arrived! They'll be by the beginning of April. After we see that everything works, especially regarding the daughterboards, I'll move on to getting the prototype case made.
EDIT: Production PCBs will be matte black with a white silkscreen. The pcbs pictured are not final.
« Last Edit: Fri, 23 March 2018, 14:22:02 by Krelbit »
Offline xondat
  • i'm not a star
« Reply #77 on: Fri, 23 March 2018, 14:17:21 »
They're terrible, I love it.
Offline Krelbit
  • Switchmod.net
    • Switchmod
« Reply #78 on: Fri, 23 March 2018, 14:51:55 »
Sadly, no one in the GB will get these in yellow. (unless you want to assemble some pcbs yourself)
Offline ghostjuggernaut
Re: [IC] MEME | Gasket-Mount 65% (Update 3/23/2018)
« Reply #79 on: Fri, 23 March 2018, 14:54:13 »
I would 100% get this in yellow if offered. Tired of green and black pcbs.
Offline Krelbit
  • Switchmod.net
    • Switchmod
« Reply #80 on: Tue, 27 March 2018, 21:36:57 »
Well, it seems I'll also be having a vote on the PCB color in the near future. I've seen many people tell me they prefer a non-black pcb.
Offline lac29
« Reply #81 on: Tue, 27 March 2018, 22:27:31 »
I personally could care less about pcb color. As long as their is a plain ol black case version, I think I'm in. 65% + QMK + USB-C + split backspace makes this a winner for me.
Offline xondat
  • i'm not a star
« Reply #82 on: Wed, 28 March 2018, 05:22:14 »
So you care a little bit? :p
Neon pink PCB pls.
Offline Krelbit
  • Switchmod.net
    • Switchmod
« Reply #83 on: Wed, 04 April 2018, 23:21:50 »
4/4/2018 Progression updates:
A purchase order has been sent in for the gaskets. They're cheaper than I expected, so now I'll make $27 from each board instead of $11. Go me.
It turns out that my anodization contact has told me that their anodization shifts from metal to metal and batch to batch, so they won't be able to get me consistent color chips at all. Nevertheless, I have been assured that the quality is quite high and I will see for myself when I order the prototype.
Speaking of the prototype, I have quotes coming in this weekend and expect to place an order for the prototype after the prototype pcbs have been tested and confirmed working. The parts are on their way to be assembled and tested as of today.
Also, here's a handful of renders using JTK Yolch and JTK Red Riot, because I gotta cross-promote to hit MOQ these days.
Offline peggisan
Re: [IC] MEME | Gasket-Mount 65% (Update 4/4/2018)
« Reply #84 on: Thu, 05 April 2018, 01:35:24 »
will there be an option for just the PCB? been looking for a 65% uses micro/typeC
Offline Atredl
« Reply #85 on: Thu, 05 April 2018, 01:39:44 »
It uses a daughter board for the usb connection so it probably won’t work for your board.
Offline Krelbit
  • Switchmod.net
    • Switchmod
« Reply #86 on: Thu, 05 April 2018, 08:39:27 »
If you can somehow find a case and plate with daughterboard cutouts and no screw mounts, sure, I can sell you a set of pcbs. Otherwise you're out of luck.
Offline lac29
« Reply #87 on: Thu, 05 April 2018, 08:59:12 »
Would you be willing to sell the prototypes if they work?
Offline Krelbit
  • Switchmod.net
    • Switchmod
« Reply #88 on: Thu, 05 April 2018, 09:21:42 »
The case, or the PCB? Only a couple PCBs will be assembled to see if the whole Jst connector mechanism works.
If you (or anyone) want(s) to buy the prototype case let me know. :D Just know that it'll probably be in the neighborhood of $700 for the prototype kit. (You're guaranteed a spot, I guess) I just need it to take pictures and test if everything is working alright.
« Last Edit: Thu, 05 April 2018, 09:26:09 by Krelbit »
Offline lac29
« Reply #89 on: Thu, 05 April 2018, 09:27:15 »
So no chance of the prototype (everything) for whatever the production models will cost?
Offline Krelbit
  • Switchmod.net
    • Switchmod
« Reply #90 on: Thu, 05 April 2018, 09:38:51 »
No.
I'll end up fronting the $600 cost on the prototype myself. I've already bought PCBs and gaskets and that's where the extra 100 comes from. If anyone really wants in on the board they can buy the prototype, but they have to keep in mind that they probably won't get it until the gb is running.
Prototypes naturally cost more than their production counterparts so having the prototype set significantly higher if someone wants to buy it seems alright with me.
Offline floristfran
  • I Wanted a foam bath and i got a slimy eel bath
« Reply #91 on: Thu, 05 April 2018, 12:45:20 »
have been hype since you first posted the first renders, going to buy this so hard
(also gmk watster pls)
Offline Krelbit
  • Switchmod.net
    • Switchmod
« Reply #92 on: Thu, 05 April 2018, 13:50:16 »
Thanks for the support! Hopefully, I can move to group buy by the end of this month or the beginning of next month.
GMK Watsters were run and have shipped, try and get some off mechmarket or something lol
Offline Koobaczech
  • Don't forget to smile :)
    • Pearlboards
« Reply #93 on: Thu, 05 April 2018, 14:00:20 »
I've got some watsers for you bro, just gonna have to dig through my trash can
Offline floristfran
« Reply #94 on: Thu, 05 April 2018, 14:46:16 »
Sent from my ONE A2005 using Tapatalk
Offline Koobaczech
    • Pearlboards
« Reply #95 on: Thu, 05 April 2018, 19:40:54 »
Its an inside joke, i received some broken and had to throw them away xD
Offline Krelbit
  • Switchmod.net
    • Switchmod
Re: [IC] MEME | Gasket-Mount 65% (Update 4/10/2018)
« Reply #96 on: Tue, 10 April 2018, 23:43:50 »
Road bumps and Progress: 4/10/2018
Snag hit, we've got some small problems with the daughterboard, JST connector cables, and the PCB.
We've rectified our issues but will need new prototype pcbs. +1 1/2 week to project time while those arrive.
Thanks to Wilba for helping us out with our troubles, and for a hookup.
Prototype Case Status: Waiting for a quote, and ready to place an order.
Gasket Status: In production.
Removed colors Brown, Orange, Yellow, and Olive Drab from color table. Orange will be available as a badge color, but not as a case color. Gold is close enough to yellow to not need both.
Want to vote the on final PCB Color? Cast your vote here: https://www.strawpoll.me/15478962
« Last Edit: Tue, 10 April 2018, 23:48:45 by Krelbit »
« Reply #97 on: Wed, 11 April 2018, 00:16:39 »
Removed colors ... Yellow ... from color table.
angery
Offline Krelbit
  • Switchmod.net
    • Switchmod
« Reply #98 on: Wed, 11 April 2018, 00:28:48 »
angery
no eyebleed banana boards on my watch
« Reply #99 on: Wed, 11 April 2018, 00:46:48 »
angery
i'm gonna reano my alice yellow because of this
