Author Topic: Now try Plum Niz84. emm, not bad. What do you think?  (Read 1995 times)
Offline KPrepublic
    • KPrepublic
« on: Fri, 09 March 2018, 01:23:23 »
191051-0
Offline Kevadu
Re: Now try Plum Niz84. emm, not bad. What do you think?
« Reply #1 on: Fri, 09 March 2018, 03:02:45 »
Will it be available in a heavier weight than the 35g Plums always seem to get?   Because that's what keeps me from trying one...
Offline KPrepublic
    • KPrepublic
« Reply #2 on: Fri, 09 March 2018, 03:07:38 »
I searched on their website. They provide 45g and 35g What I tried is 35g.  I am thinking of custom it with heavier weight someday. But that's just for curiousness. I am not keen on heavier for daily use, though. :)
Offline floristfran
  • I Wanted a foam bath and i got a slimy eel bath
« Reply #3 on: Fri, 09 March 2018, 15:26:42 »
was thinking about picking one of these up to put some heavy domes in it, i just wish it had a nicer case..
Offline KPrepublic
    • KPrepublic
« Reply #4 on: Fri, 09 March 2018, 18:52:26 »
The case is plastic.
