Author Topic: Beginner here - can't seem to find what I'm looking for?  (Read 1952 times)
Offline guiddqd
« on: Fri, 09 March 2018, 07:11:24 »
Hello,
I'm quite new to the world of mechanical keyboards.
What Id like to make is a 65% (at least with arrows) with alps switches and if possible bluetooth.
I found a few things that would work but they were 60% boards, none with the arrows.
I have two Dell at102's, one at101, two Wang 725 and an Apple AEK thats on its way to my home.
Is it possible to get something done with this?
Offline p_blaze
Re: Beginner here - can't seem to find what I'm looking for?
« Reply #1 on: Fri, 09 March 2018, 07:34:26 »
Hello,
Matias makes really good clone ALPS, if you are ok with a prebuilt. Otherwise LFKeyboards has a tkl alps pcb but you will need to find a compatible case.
Offline guiddqd
« Reply #2 on: Fri, 09 March 2018, 08:02:19 »
Thanks for the tip. Id rather make one myself with 'real' alps.
I'll look into this more but it seems to be a good option!
Offline p_blaze
« Reply #3 on: Fri, 09 March 2018, 09:18:40 »
Ignore i didn't read the first post properly
Offline Kavik
« Reply #4 on: Fri, 09 March 2018, 10:13:52 »
You may be interested in the 60% Matias kit. You will be able to buy it without switches, I believe, so that you can use your own real ALPs switches, and it's a little different from the typical 60% because it has arrows and a nav cluster. The only issue is that it's been in development since 2014, so who know when it will see the light of day.
https://matias.store/products/60-keyboard
Offline guiddqd
« Reply #5 on: Fri, 09 March 2018, 11:32:19 »
I thought this could work? Or am I missing something :confused:
The Matias kit is interesting, but indeed nobody knows when it will come out.
