Author Topic: "official" row numbering order?  (Read 6750 times)
Offline denym_
« on: Fri, 09 March 2018, 20:40:39 »
Well not really official but the agreed standard.
Is it R1 to Rx bottom to top or other way around. Saw both recently and just curious whoarches to a different drummer?
Regards
Offline xondat
  • i'm not a star
Re: "official" row numbering order?
« Reply #1 on: Fri, 09 March 2018, 20:41:31 »
R1 is top, R4 is bottom.
Offline Techno Trousers
  • ʘ_ಠ
« Reply #2 on: Fri, 09 March 2018, 20:58:33 »
I prefer numbering top to bottom, but I think it's up to the designer of the profile to decide.
Offline TalkingTree
    • My projects
« Reply #3 on: Sun, 11 March 2018, 03:36:21 »
R5 is bottom. *shakes fist*
Offline pomk
« Reply #4 on: Sun, 11 March 2018, 04:31:53 »
Keycap manufacturers have datasheets which provide correct naming for each row. Cherry is from A to F and SP profiles are just numbered 4 to 1.
« Reply #5 on: Sun, 11 March 2018, 10:23:44 »
https://deskthority.net/wiki/Keyboard_profile#Numbering
The ISO/IEC 9995-1 standard mandates use of letters. For the main five rows, it is A (next to space bar) to E (numerical row). Cherry, Topre and Leopold use letters.
There is no standard for using numbers instead of letters - each manufacturer that uses numbers has come up with that on their own. Because Signature Plastics uses numbers and they have been used for many runs of keycap sets, their numerical row naming has sometimes been used for runs from other manufacturers.
Almost no new keyboard uses different profiles for row A or above E any more though. Those exist mostly on vintage keyboards. You will almost always see row B (SP R4) profile used also for the space bar row and row E (SP R1) also for function keys.
BTW. Some manufacturers emboss a number on the inside of the keycap showing which mould/part it is from: e.g. "E12" for twelfth key on row E.
« Last Edit: Sun, 11 March 2018, 16:39:02 by Findecanor »
Offline xondat
  • i'm not a star
« Reply #6 on: Sun, 11 March 2018, 10:24:30 »
Offline TalkingTree
    • My projects
« Reply #7 on: Sun, 11 March 2018, 11:34:55 »
