Author Topic: Where to buy Realforce keycaps ?  (Read 15517 times)
Offline Geroximo
« on: Sun, 11 March 2018, 13:33:47 »
Hi,
is there a place where I can buy keycap sets for the Realforce keyboards?
I know you can buy keycaps for the HHKB, but I cant find them for the Realforce boards ...
Especially the ISO-DE version.
There is a ISO-DE Realforce 87UB, so why can't I purchase a set of Topre ISO-DE keycaps  :(
Re: Where to buy Realforce keycaps ?
« Reply #1 on: Sun, 11 March 2018, 13:42:43 »
widebasket sells some sets, but that's pretty much it
Offline Geroximo
« Reply #2 on: Sun, 11 March 2018, 13:56:54 »
Why aren't they selling the keycaps to their keyboards separatley just like it's done with the HHKB? ... that's ridicolous.
« Reply #3 on: Sun, 11 March 2018, 14:21:04 »
Market for them is just enthusiasts, not daily users. So not enough to justify it really.
They stopped producing custom keycaps in 2014 or so.
« Reply #4 on: Mon, 12 March 2018, 02:38:07 »
This is a really sad situation that many of us hope will one day be remedied.
Offline subcat
« Reply #5 on: Mon, 12 March 2018, 03:17:13 »
Rakuten has the printed sets in every colour save white, pink and red (the latter they just ran out of a couple days back). Amazon.co.jp has some jis sets, or you can check yahoo! auctions periodically. As for the blanks, good luck.
Offline HotRoderX
« Reply #6 on: Mon, 12 March 2018, 03:35:19 »
Unless its someone in the community running a buy. I think Topre's solution is the RGB TKL Real force they been teasing with MX stabs they been teasing. I think what will happen is the RGB series will be for "Gamers/Enthusiast" While there standard board's will be for the more mainstream market. Though honestly I kinda love my humble Realforce TKL that sports 55g domes black/black alpha's with orange/black modifiers. Just kinda has a classy upscale feel while still looking nice.
Offline nastrovje
« Reply #7 on: Mon, 12 March 2018, 03:46:46 »
Hi,
Puddsy once again with no clue and just commenting to increase that post counter...
Here are 4 different ansi keysets for cheap. On amazon jp you can find japanese layout sets. ISO I couldn't find in my quick research.
https://zenmarket.jp/rakuten.aspx?q=realforce104%2bxf0100
Offline Geroximo
« Reply #8 on: Fri, 16 November 2018, 14:58:11 »
8 Months later.
Any new sources for Realforce keycaps?
Offline phinix
« Reply #11 on: Tue, 19 March 2019, 21:13:20 »
Offline Geroximo
« Reply #12 on: Wed, 20 March 2019, 16:15:56 »
If I pay 200+ bucks for a Realforce, I want to make sure that I can buy new original keycaps for it when the old ones are worn.
As long as Realforce doesn't offer replacement keycaps, I can't buy one.  :(
Offline Hyde
  • White Tofu Extraordinaire
« Reply #13 on: Wed, 20 March 2019, 16:59:51 »
It's pretty hard to wear out PBT dyesub though, I mean it will wear out but I've had my keyboard for 5+ years and still looks almost brand new.
That being said I've recently bought this:  https://kbdfans.cn/collections/electrostatic-capacitive-keycaps/products/in-stock-ec9009-keycaps-set
While I haven't put them on my keyboard yet (will try this weekend), but upon first glance this actually look very good.
Will report back once I put them on keyboard.  :P
Offline HotRoderX
« Reply #14 on: Thu, 21 March 2019, 02:50:13 »
Honestly if it makes you feel even bit better never heard or seen anyone mange to ware out a set of Dye subbed or double shot keycaps. In fact if I am not mistaken IBM Model F/M's used dye subbed keycaps and are getting into there 40th Anniversary soon  Most don't have worn out keycaps
Offline whalematrontron
« Reply #15 on: Thu, 21 March 2019, 03:46:45 »
You can always buy aftermarket keycaps from the like of KBDfans
Offline subcat
« Reply #16 on: Thu, 21 March 2019, 03:58:28 »
if your concern is with them wearing out you don't really need to worry, unless you have a problem with a relatively small amount of shine (and only then after probably 5+ years of heavy use)
