Author Topic: Is it possible to buy a part of stabilyzers  (Read 1491 times)
Offline demas
« on: Mon, 12 March 2018, 22:32:20 »
I need to buy part of stabilizers. Those which is placed on the buttons (see the attachment).
Is it possible or do I need to buy full stabilizers ?
Offline xondat
  • i'm not a star
Re: Is it possible to buy a part of stabilyzers
« Reply #1 on: Mon, 12 March 2018, 22:36:16 »
I haven't seen anywhere where you can just get those, so just get the full set (thankfully they're cheap).
Offline Tactile
« Reply #2 on: Mon, 12 March 2018, 23:19:04 »
Those pieces, called "stabilizer inserts", are not usually included with the stabilizers. You must buy them separately.
REΛLFORCE
