Author Topic: [IC] Lumina - Corian 60% by Greenwald Designs (GB NOW OPEN)  (Read 40236 times)
Offline Daellin
Re: [IC] Lumina - Corian 60% by Greenwald Designs
« Reply #100 on: Thu, 10 May 2018, 00:27:13 »
It says any 60% PCB is compatible, but I presume that it needs to use the Corian plate to be of any use?
I want to buy the case and transfer over my DZ60 PCB but seems like that won't be possible. It's the DZ60 Split space plate.
Offline Atredl
« Reply #101 on: Thu, 10 May 2018, 00:56:23 »
It’s totally possible but you’ll need to desolder your PCB and rebuild it in the Lumina plate. Split space is supported based on the layout picture in this thread. Your current plate won’t work in the Lumina though.
Offline bkim14
« Reply #102 on: Sun, 13 May 2018, 03:27:18 »
I would definitely be in! Gorgeous
Offline schlep
« Reply #103 on: Sun, 27 May 2018, 08:55:58 »
Any updates?
Offline lumpofunworth
  • I’m a guy, that does stuff, with things, for fun.
« Reply #104 on: Mon, 18 June 2018, 22:21:27 »
Any updates?
I’m also wondering, this is a must buy for me so I hope it gets to group buy
I like keyboards like I like people... I like keyboards a bit more come to think of it... nvm
Offline dr_unconscionable
    • [sqeleton]
« Reply #105 on: Mon, 18 June 2018, 22:23:56 »
Only found this recently and filled out the survey belatedly since it's still open. I hope the project hasn't lost steam! Very interested in this!
Offline lordgiblite
« Reply #106 on: Sat, 30 June 2018, 18:37:15 »
Any updates?
Any updates?
Yes it's still in process, he was waiting for new prototypes with angled bottoms. There should be an update shortly!
Offline GreenwaldDesigns
« Reply #107 on: Sat, 30 June 2018, 20:25:36 »
Any updates?
GB is still happening, I am just working with the manufacturer to get the best prices and options for everyone. Looking to add some more color options, as well as material options for the various parts of the board.
« Reply #108 on: Sat, 30 June 2018, 20:26:14 »
Still happning. Waiting on V2 prototype, and figuring out pricing and options. Should have an update very soon!
Offline Dovan1405
« Reply #109 on: Sun, 05 August 2018, 03:15:19 »
any possible date of when this will happen? in sept or something like that?
just filled out the survey.
Offline eas
« Reply #110 on: Sun, 12 August 2018, 11:49:27 »
Is there a distant possibility for a xd75 plate?
Offline Atredl
« Reply #111 on: Sun, 12 August 2018, 14:03:27 »
He mentioned that he’s going to release the plate files so that anyone can make their own custom plate.
Offline Zilleon
« Reply #112 on: Sun, 12 August 2018, 14:50:29 »
This is so unique and looks awesome, I'm definitely interested!
Offline pixelpusher
« Reply #113 on: Mon, 13 August 2018, 13:30:04 »
GB is live, fyi.
I have a question or two, but I'll wait until the GB thread comes up.
https://www.luminakb.com/
Offline schlep
« Reply #114 on: Tue, 14 August 2018, 16:40:40 »
Ive already made my order.
Is there any MOQ?
« Reply #115 on: Tue, 14 August 2018, 18:06:12 »
GB is now live! Bear with me while I work on a Thread for Geekhack, but in the meantime, come over to luminakb.com to check out all the different options, and https://www.reddit.com/r/mechmarket/comments/96zu7d/gb_lumina_corian_60_custom_keyboard_group_buy_now/ for some more details on the GB!
Thanks
« Last Edit: Tue, 14 August 2018, 18:09:14 by GreenwaldDesigns »
« Reply #116 on: Tue, 14 August 2018, 18:07:31 »
GB is now live, and I will be open sourcing the plate files, so you will be able to get a custom plate made in whatever material you might be able to get your hands on!
Thanks
« Reply #117 on: Tue, 14 August 2018, 18:08:24 »
Thanks
Offline schlep
« Reply #118 on: Wed, 15 August 2018, 07:38:31 »
Ordering from Singapore here. I believe you will invoice shipping separately?
« Reply #119 on: Wed, 15 August 2018, 09:05:29 »
Hi! That would be correct!
Offline Solotov
« Reply #120 on: Wed, 15 August 2018, 09:12:38 »
This is a type of materials I have been waiting for a keyboard case. Sadly, I'm not into 60%. Hope there will be TKL in the future. Great board!  :thumb:
Flex is love, flex is life.
« Reply #121 on: Wed, 15 August 2018, 11:57:33 »
We will absolutely be making our way around the various layouts!
« Reply #122 on: Wed, 15 August 2018, 11:59:02 »
GB now live here: https://geekhack.org/index.php?topic=97020.0
Awaiting thread approval, but I am now closing this thread. Come on over for all the updated details!
