Author Topic: [IC] Lumina - Corian 60% by Greenwald Designs (GB NOW OPEN)  (Read 40237 times)
Offline GreenwaldDesigns
Re: [IC] Lumina - Corian 60% by Greenwald Designs
« Reply #50 on: Wed, 14 March 2018, 12:14:26 »
Better get voting! Cameo White, Cosmos Prima, and Elderberry are in the top 3 right now!
Im going to be sooooo happy if Elderberry makes it! :D
Me too! Probably one of my favorite colors in the list of options. :D
Offline Vigrith
« Reply #51 on: Wed, 14 March 2018, 12:17:12 »
White, Elderberry, Limestone. Hoping not all of them run at the one time though as I can't afford all 3 haha
« Reply #52 on: Wed, 14 March 2018, 12:21:48 »
Honestly, I might do multiple runs :) Who knows :)
Offline gutsack
« Reply #53 on: Wed, 14 March 2018, 14:58:00 »
Submitted the form, this looks so awesome. Rare to see a new material that actually seems worth doing, I'm excited about this!
« Reply #54 on: Wed, 14 March 2018, 14:58:51 »
Thank you! I can tell you I am equally as excited :D
Offline Etherealsound
« Reply #55 on: Wed, 14 March 2018, 22:13:39 »
Dam, the real problem is choosing which color to go with. They're all really nice.
Offline TheEerieCold
« Reply #56 on: Wed, 14 March 2018, 22:58:55 »
I can help... Elderberry !!
Matrix Abel+ Ver.Dark / Matrix 8XV2.0 (Red) / Matrix 8XV2.2 (Blue) / Matrix 8XV2.2 (Caustic Custom) / Matrix Noah / Matrix Abel X RX-178 Ver.CA / Matrix 8XV2.0 ADD (Silver) / Matrix Falcon (Nebula) / Matrix Vita (McFlurry) / Matrix ME SE (McFlurry)
« Reply #57 on: Wed, 14 March 2018, 23:26:47 »
If anything, you could always get 3 Luminas, all different colors :) Another cool thing is that you can mix and match colors. I tried out black top with white bottom, and it does look pretty cool!
Offline LeoShi
« Reply #58 on: Thu, 15 March 2018, 00:37:10 »
wait, we can mix colors?  that would be so coooool! :p :p :p
Offline Xantus
« Reply #59 on: Thu, 15 March 2018, 05:38:48 »
Pls add switch top removal option and place the in switch led to the south side if possibe!
« Reply #60 on: Thu, 15 March 2018, 14:23:10 »
Will add that to the list of things to consider!
Offline Poesjuh
« Reply #61 on: Thu, 15 March 2018, 14:28:52 »
In switch led to the south is a ***** with cherry profile caps though :S
Sent from my iPad using Tapatalk
Offline Vigrith
« Reply #62 on: Thu, 15 March 2018, 14:34:23 »
Switch top removal, absolutely. South leds, absolutely not.
Offline Atredl
« Reply #63 on: Thu, 15 March 2018, 14:41:24 »
I wouldn’t buy a pcb if it came with north facing leds.
Offline FrostyToast
  • Litshoard
« Reply #64 on: Thu, 15 March 2018, 14:54:10 »
So... Would you call this a...
Corian custom?
Quote from: elton5354
« Reply #65 on: Thu, 15 March 2018, 15:01:41 »
Corian custom?
Yes I would XD
« Reply #66 on: Fri, 16 March 2018, 10:53:09 »
PCB will be optional, as the case works with any standard 60% pcb! I am working to get the PCB to be what most people will want, but in the event people are not satisfied with what it is in the end, other PCB can definitely be used with the Lumina.
Offline beekey
Re: [IC] Lumina - Corian 60% by Greenwald Designsght
« Reply #67 on: Fri, 16 March 2018, 12:38:43 »
Some questions:
1. the plate ist custom for this case?
2. Normal 60% plates will not work?
3. the PCB offers a split space layout, but the plate does not, right?
Looks so nice, but I love split space. :)
« Reply #68 on: Fri, 16 March 2018, 13:28:31 »
Some questions:
Answers to your questions:
1. Plate is custom for this case, but the plate files will be open sources most likely so that people can do whatever layout they might want with this case.
2. Normal 60% plates will not work with this due to the way that the case is constructed.
3. PCB and Plate will both offer split spacebar, plate will be updated to reflect this, as the plates I have now are just standard. But yes, the plate and pcb will offer the same layouts.
Offline beekey
« Reply #69 on: Fri, 16 March 2018, 16:22:02 »
Some questions:
Uh oh, this sounds like a might get an awesome split space super case. :) Looking forward to the GB!
Offline adamchevy
  • You can grow ideas in the garden of your mind.
« Reply #70 on: Fri, 16 March 2018, 19:01:24 »
I saved my $$$ to put down on the Rama M60-A, but after seeing this I am going to hold off. This looks spectacular!
« Reply #71 on: Fri, 16 March 2018, 20:32:06 »
Wow! That is a huge compliment! Thank you!
« Reply #72 on: Fri, 16 March 2018, 20:32:43 »
Some questions:
Should be pretty awesome! :D
Offline Simen
« Reply #73 on: Fri, 16 March 2018, 21:08:19 »
pretty nice
Offline OfTheWild
  • Make things. Have fun.
    • Studios of the Wild
« Reply #74 on: Fri, 16 March 2018, 21:22:23 »
Tossing in my 2cents that I saw these in person finally at the Columbus meet and I can say they are stunning.  :thumb:
-Dana
Offline dead_pixel_design
  • IIIV is not a Roman Numeral. Positive Vibes.
« Reply #75 on: Fri, 16 March 2018, 21:25:49 »
Interested
« Reply #76 on: Sat, 17 March 2018, 10:03:02 »
Man I really want to see samples of cosmos prima and elderberry. This gb got hypeeed
« Reply #77 on: Sat, 17 March 2018, 12:04:53 »
:D
« Reply #78 on: Sat, 17 March 2018, 12:05:19 »
Working on getting samples for those! Stay Tuned!
Offline Gamatatsu
« Reply #79 on: Sat, 17 March 2018, 12:48:37 »
Would be in for winkeyless blockers! :thumb:
« Reply #80 on: Sat, 17 March 2018, 12:55:23 »
If enough people want it, I can offer it! Fill out the poll, and leave me a message so I can keep in mind that WKL is wanted :)
Offline nathanchere
« Reply #81 on: Sat, 17 March 2018, 22:34:02 »
Would recommend looking at the Norbatouch project which started out with a Corian option but never made it past the prototype stage. It's supposedly very difficult to work with when doing any kind of details, so I would expect the blockers in a winkeyless or similar layout would add a lot to the overall project cost. I'd like a WKL myself but would even more so like to see this happen at all so would suggest stick to standard layout only for the first run and you can always look at a WKL support in round 2 if the first round is successful.
For colour I voted Anthracite since you only allow one option but I'd also be happy to buy in Elderberry or White as well.
Offline ArchDill
« Reply #82 on: Sat, 17 March 2018, 22:55:55 »
This is a very interesting concept! Excited to see how these turn out.
Offline emenelopee
  • *klomp klomp klomp* I step on your house 🦖
« Reply #83 on: Sat, 17 March 2018, 22:57:27 »
What screws are you using for the final? Any chance of hex heads or something sexier than the silver phillips?
Loving the new material and split space. I'm interested.
Also any chance of a solid Corian bottom/no diffuser?
EDIT: Voted for red + brass plate. Nice.
« Last Edit: Sat, 17 March 2018, 23:04:43 by emenelopee »
Offline Atredl
« Reply #84 on: Sun, 18 March 2018, 00:10:27 »
Did you mean the Norbaforce? I don’t think Corian was ever considered for the Norbatouch.
If I remember correctly, the thin sidewalls like these were where Corian would have issues.
« Reply #85 on: Sun, 18 March 2018, 02:02:11 »
Hey! Thank you for your input! While I was designing this board, I did come across the Norbaforce thread as a friend linked it to me. I have worked with Corian quite a bit, and have become very familiar with it's properties over the last 4 or so months, so this board is designed specifically to keep in mind the limitations of Corian and it's possiblities. As for the blocked and winkeyless tops that I am thinking of offering, the thickness of the material is well within the needed tolerances for the design to work! The Cost will not be too much more, as it would be a very small variation of the standard layout file type. I have taken into account the various aspects of the material and cnc costs as well!
Thank you very much for your feedback, I will be taking note of your comment about only one option.
« Reply #86 on: Sun, 18 March 2018, 02:02:58 »
Thank you! There is still work to be done, based on feedback that I have gotten, but I hope that I will not disappoint!
« Reply #87 on: Sun, 18 March 2018, 02:05:00 »
For the final, I was going to take a look at the various screw options, but seeing as the philips head screw is the most common and easily accessible, it will most likely be that. However, in terms of aesthetic, hex screws would indeed be sexy, so I will see what I can do!
As for the solid corian bottom, I am working on an update to the design that addresses that, as I have had multiple people comment that they would like to see a solid bottom to the case. Stay tuned!
Offline vewy_nice
« Reply #88 on: Mon, 19 March 2018, 07:40:07 »
Check out https://www.boltdepot.com 's socket products section!
They have *everything*, with bulk pricing, and a bunch of different materials, and also a nice selection of black oxide coated fasteners ;)
Also, they're a USA company, and ship *super* fast.
I use them for all my custom screw/bolt needs.
« Reply #89 on: Mon, 19 March 2018, 10:09:04 »
Bookmarked. Thank you! I will definitely look into this website for some good screws to use!
Offline pngu
  • send noots
« Reply #90 on: Wed, 28 March 2018, 03:59:13 »
Sorry for the offtopic, but a Canadian venture called "Maple Computing" sounds so... right. Intuitive.
If I were to push through with the freelance web dev plans that resurface whenever I'm on the verge of ragequitting my job and called it Bratwurst Design, do you guys reckon that'd hinder my acquisition of clients or does the same vibe come across?
Nice keeb design dude. Not my taste but I appreciate the effort you put into this.
Offline online
« Reply #91 on: Tue, 03 April 2018, 06:24:48 »
I thought I'm done with 60% until I see this AMAZING case.
Love the white classy look!
I would love to fit YD60BLE in there!!
Will you be happy to share the plate data once the GB finished? So that people could make their own plate with it.
« Reply #92 on: Wed, 04 April 2018, 00:21:45 »
Thanks! I will indeed be open sourcing the plate files for people to be able to make their own plates for the Lumina!
Offline nathanchere
« Reply #93 on: Sat, 07 April 2018, 07:31:35 »
This has my vote for most anticipated mech keyboard project of 2018.
« Reply #94 on: Sat, 07 April 2018, 11:23:09 »
Thank you! I am currently working on getting updated prototypes with the angled bottom. Should be able to show them soon! After that, I will open the GB
Offline DasGnome
« Reply #95 on: Fri, 04 May 2018, 05:50:08 »
Any updates?
Offline Winbrick
« Reply #96 on: Mon, 07 May 2018, 13:26:21 »
I want one of these so, so bad.
Offline phorx
  • ¯\_(ツ)_/¯
« Reply #97 on: Mon, 07 May 2018, 15:18:50 »
Pretty cool to see a new material in the mix!  60% isn't my fav size, but I hope this is a success.
Offline Eddie_Caps
« Reply #98 on: Tue, 08 May 2018, 23:42:53 »
What is the weight of corian compared to aluminum?
Offline Atredl
« Reply #99 on: Tue, 08 May 2018, 23:49:32 »
Looks like Corian weighs 63% as much as 6061 Aluminum.
Corian: 1.7 g/cm^3
Aluminum: 2.7 g/cm^3
That said, weight isn’t everything when it comes to determining quality.
