Author Topic: [IC] Custom Engraved Switch Housing  (Read 4655 times)
Offline Mousy
  • I <3 tootall
    • IG
« on: Tue, 13 March 2018, 23:22:32 »
Hello all,
I decided to try and see if it was possible to add another level of custom to my keyboard and engrave my own tag onto the switch housings. The result was as follows!
Engraving Samples
191516-0
191518-1
Please do note that the positioning of the engraving isn't going to be the final place it goes. For the finished pieces it will sit where the GATERON lettering currently is.
I would really appreciate any feedback you have on this idea and if you would like to see it become available for a Group Buy! The current information I can give is the following:
Same switch top as used in Zeal switches.
Pricing is waiting on confirmation from engraving company will update ASAP.
I will provide the housing tops.
Interest Check Form
- White Kira 60 | Black Kira 60 | TGR Jane v2? -
Re: [IC] Custom Engraved Switch Housing
« Reply #1 on: Tue, 13 March 2018, 23:30:54 »
i guess i could put one on my keychain...
Offline ArchDill
« Reply #2 on: Tue, 13 March 2018, 23:32:53 »
Haha I can imagine trying to engrave a set for a full board.
« Reply #3 on: Tue, 13 March 2018, 23:56:41 »
filled form
Offline midnight2903
« Reply #4 on: Wed, 14 March 2018, 09:21:38 »
This is some next level shizzzz
Offline Remsky
  • Lubed switch count > Puddsy post count
« Reply #5 on: Wed, 14 March 2018, 09:59:49 »
Do you have any idea about cost? Just a ballpark estimate, if you have one.
TGR Jane v2 - GSKT00(coming) - TGR Jane CE V2 - TGR Poly alice - LZ Physix - Matrix 8XV 2.0 - RS - LZ FE - Dalco 959 Mini GT edition (coming) - Mc65 - Hiney TKL one - HHKB Pro 1 - 25th anniversary edition HHKB pro Hybrid - 30th anniversary Filco 2S keyboard
Offline Mousy
  • I <3 tootall
    • IG
« Reply #6 on: Wed, 14 March 2018, 10:04:25 »
I'm at work currently and am ohinging the company when I finish in 2 hours.
Offline roosta
  • o o f.
« Reply #7 on: Wed, 14 March 2018, 12:32:39 »
This is some next level endgame material. I'm not sure how this would play out for a full-sized keyboard though. Would you mold your own "blank" housings and then engrave, or would you just engrave over the Gateron logo?
Pok3r w/ 62g Zealios, DZ60 w/ 65g Zealios, XMIT Hall Effect, Minivan w/ Gateron Yellows, Quickfire Rapid-i w/ MX Browns, Let's Split w/ MX Clears, etc...
Offline Rob27shred
  • Insane in the Membrane! 👻
« Reply #8 on: Wed, 14 March 2018, 12:43:09 »
This is something I am curious about as well as I personally think engraving over the manufacturer's logo wouldn't turn out so hot. I filled out the IC form as I am interested in a batch of these. Although I would personally like to see the option of having the engraving done in a few different spots on the top housing if that's feasible. I actually like the area you had engraved for the samples TBH. On top where the manufacturer's logo usually is would be nice, but I would only want that if you can source blank top housings.
Offline Mousy
  • I <3 tootall
    • IG
« Reply #9 on: Wed, 14 March 2018, 13:17:33 »
I would be sanding down the current logo to the point where you couldn't tell it was there to start with. The structure of the housing isn't changed through any of the process.
Offline BobCarltheThird
« Reply #10 on: Wed, 14 March 2018, 14:11:00 »
Filled out but would there be an option for me to just get one switch engraved? This could be really useful to help with finding one of my travel boards if I loose it somewhere.
***loads of Vaseline for my meme TMO50 -- Acereconkeys
Offline Rob27shred
« Reply #11 on: Wed, 14 March 2018, 14:49:26 »
I think that would work out pretty good, didn't even think about removing the manufacturer's logo. :thumb:
Offline bminhz
« Reply #12 on: Wed, 14 March 2018, 17:01:59 »
interested in this! wonder if you could also do stuff like color dyeing for the housings/stems then I would be all over this  ;)
Offline Mousy
  • I <3 tootall
    • IG
« Reply #13 on: Wed, 14 March 2018, 18:10:52 »
These are the test housings I gave to the company to test with. Two sanded one stock.
« Last Edit: Wed, 14 March 2018, 18:12:52 by Mousy »
