Author Topic: [KEYCAP] Total Recall Hand Painted Keycap for Cherry MX Switches  (Read 3358 times)
Offline chrisgem
    • PLANFAB Shop
Hi all,
Check out our Total Recall Keycap for Cherry MX Switches.
Probably the most iconic boobies in cinema and the awesome line "Not free...but available" just adds to the fun of the scene!!
If you need a little reminder, check it out: https://www.youtube.com/watch?v=EiylTqSAiaM
This is a 3d modeled and 3d printed in high detail resin keycap.
It is tested on cherry mx switches so it will work on every similar switch.
If you want to see more pics or purchase it, check out our etsy shop:
https://www.etsy.com/shop/PLANFAB?ref=l2-shopheader-name&section_id=23214385
Feedback and comments are welcome.
Cheers
Christos
Offline Techno Trousers
  • ʘ_ಠ
Re: [KEYCAP] Total Recall Hand Painted Keycap for Cherry MX Switches
« Reply #1 on: Fri, 16 March 2018, 10:37:13 »
I can't even
Offline noSatellite
  • perpetual n00b
« Reply #2 on: Fri, 16 March 2018, 19:43:01 »
What I lack in time, resources, and knowledge I make up for in passion, enthusiasm and ignorance.
Offline TalkingTree
    • My projects
« Reply #3 on: Fri, 16 March 2018, 23:31:47 »
A proper homing key with nipples.
Offline ArchDill
« Reply #4 on: Fri, 16 March 2018, 23:39:06 »
I laughed way too hard at this...
Offline chrisgem
    • PLANFAB Shop
« Reply #5 on: Sat, 17 March 2018, 16:28:28 »
Thank you for your comments guys!!
We also had some laugh while making it!!  :D
