Author Topic: PCB makers, can you verify my design?  (Read 1913 times)
Offline BDhoel
« on: Sun, 18 March 2018, 10:12:19 »
Hello everyone,
Can someone help me verify my PCB design? Here is my layout http://www.keyboard-layout-editor.com/#/gists/192597c47f1e4330ec8626c5ada6497d. My concern is about the placement of stabilizers and the foot print of non 1u key. This is my PCB design
https://easyeda.com/editor#id=|a8e4d8bbd6be4d99884cb32722743e86
Thank you.
Offline TalkingTree
    • My projects
Re: PCB makers, can you verify my design?
« Reply #1 on: Sun, 18 March 2018, 13:35:44 »
Move:
U14 (and the stab) 10 mil to the right;
U15 10mil to the right;
U29 20mil to the right;
U42 (and the stab) 10 mil to the right;
U55 and U56 10 mil to the right;
U57 and U58 20 mil to the right;
Everything else looks fine to me.
Offline BDhoel
« Reply #2 on: Mon, 19 March 2018, 10:04:13 »
Move:
Thanks for your time to verify my PCB design. I really appreciate it.  :thumb:
Offline TalkingTree
    • My projects
« Reply #3 on: Mon, 19 March 2018, 15:09:08 »
You're very welcome. When in doubt you can generate a plate through swill's builder and import the .dxf in your EasyEDA project to see if everything is aligned properly.
