Author Topic: Matias Tactile Pro users: do you prefer standard or mini?  (Read 2294 times)
Offline macguy80
« on: Thu, 22 March 2018, 02:35:39 »
Just wondering if those who own it have any opinions about the layout, or of the build quality of one vs the other.
One of the two will be my next purchase.
Offline rich1051414
Re: Matias Tactile Pro users: do you prefer standard or mini?
« Reply #1 on: Thu, 22 March 2018, 11:10:49 »
Build quality is the same on both of them. It totally depends on what you need. I own the mini and love it.
Offline enrique.aliaga
« Reply #2 on: Thu, 22 March 2018, 14:35:32 »
I own the Mini Tactile Pro. Bought in December 2015.
A few months ago the switch under the right arrow key stopped registering. Even though the keyboard spent most of the time inside its box (I constantly switch around my boards).
I’m slightly disappointed by its reliability. It should not have broken this soon. Anyways, I guess a switch swap should fix the issue. Gotta learn to desolder/solder first, though.
To your question, the Mini’s Layout is quite comfy. It’s compactness allows for a more natural right-hand position (mouse closer to keyboard).
Offline Blaise170
  • ALPS キーボード
    • XYZ
« Reply #3 on: Mon, 26 March 2018, 08:37:57 »
I quite like my Laptop Pro. All of the switches are still in good condition, though I might swap out for Green Alps or something similar in the future. Only real complaint I have is that it's a non-standard layout and Matias doesn't offer PBT caps (yet) so once you wear down the cheap pad print keys you'll have to buy a new set.
Offline klennkellon
  • I like bottoming out
« Reply #4 on: Tue, 27 March 2018, 00:00:23 »
Mini, but as much as I like the styling of the case it seems dumb to have so much bezel on a compact layout.
