Author Topic: In weight, what is the Korean-spring equivalent of Membrane Buckling Springs?  (Read 2197 times)
Offline enrique.aliaga
Hello guys and gals!
I would like to start modding some Cherry MX Clears to turn them into "Ergo Clears". I know that 62g (Korean spring) is the most popular, although 65g and up are also used.
Given my dislike for the weight of Membrane Buckling Springs (on my IBM Model Ms), I was wondering what would be the Korean-spring equivalent of Membrane Buckling Springs, weight-wise? And now that we are on the topic, what would be the equivalent of Capacitive Buckling Springs (Model F, whose weighting I find quite nice)?
Offline Techno Trousers
  • ʘ_ಠ
Approximately 80g for membrane BS, 65g for capacitive BS.
But if you want the closest experience to bucking spring you can get in Cherry mount, you want the Kailh+Novelkeys thick click box switches. Navy is approximately the weight of membrane, and jade is approximately the weight of capacitive.
« Last Edit: Thu, 22 March 2018, 22:07:16 by Techno Trousers »
Offline floristfran
  • I Wanted a foam bath and i got a slimy eel bath
wait, so you dont like the weight of the model m? so are you asking so you dont accidentally buy them?jw
I already have a bunch of M’s. I am not 100% fond of their weight, but I still use them regularly (though I am now using an F).
