Author Topic: GMMK-TKL  (Read 2593 times)
Offline TheInverseKey
  • You can run but you cannot hide!
GMMK-TKL
« on: Fri, 23 March 2018, 09:45:46 »
Hi,
I just came across this board and was wondering how well it stands up with other solderless designs.
Also would box switches work with this board? https://www.pcgamingrace.com/products/gmmk-tkl-tenkeyless-customized
Thanks
Offline lemur
  • personal text
Re: GMMK-TKL
« Reply #1 on: Fri, 23 March 2018, 10:50:25 »
I have one and box switches do work on the 'barebones' TKL i purchased last month.
the stabilizers on it are kind of crap, ..depending on how strongly you feel about that kind of thing.. you may find them adequate with clipping/lubing.. or you might budget in some new plate mount stabilizers with the purchase of this.
keyboards
Re: GMMK-TKL
« Reply #2 on: Fri, 23 March 2018, 11:38:04 »
Can you explain what level of crap compared to stabilizers of a k70.  Thanks
Offline lemur
  • personal text
Re: GMMK-TKL
« Reply #3 on: Fri, 23 March 2018, 14:07:21 »
ive never used one of those, sorry.
keyboards
