Author Topic: HHKB 2 + iPad possible?  (Read 2417 times)
Offline monkt
« on: Fri, 23 March 2018, 22:29:12 »
Supposedly the HHKB 2 won't work with an iPad because the power draw is too high. But might it work with the Apple Lightning to USB 3 Camera Adapter, seen here:
https://www.apple.com/shop/product/MK0W2AM/A/lightning-to-usb-3-camera-adapter
This adapter allows a USB device to be plugged in to the iPad while simultaneously having the iPad plugged into a charger. Would this solve the problem?
Can anyone verify whether they've gotten their HHKB 2 to work with an iPad, and if so, how?
Offline Belfong
Re: HHKB 2 + iPad possible?
« Reply #1 on: Fri, 23 March 2018, 22:31:27 »
I have that cable and no, it doesn't work with HHKB2.
It does work with my other 60% MX keyboard though. And it worked with the Code Keyboard as well.
http://www.ringgit.me/2016/08/how-to-use-ipad-with-wired-mechanical.html
« Last Edit: Fri, 23 March 2018, 22:33:49 by Belfong »
Offline monkt
« Reply #2 on: Sat, 24 March 2018, 10:25:30 »
Thanks. I wonder if it might work with Hasu's controller installed since that has a lower power draw.
