Author Topic: Lubing NovaTouch stabilizers  (Read 3602 times)
Offline zslane
« on: Sat, 24 March 2018, 12:17:57 »
Has anyone found an effective way to lube the stabilizer arms of a NovaTouch without taking the plate apart from the domesheet/PCB?
Offline MajorKoos
  • 1 life please. Extra large.
Re: Lubing NovaTouch stabilizers
« Reply #1 on: Sat, 24 March 2018, 13:30:29 »
Offline zslane
« Reply #2 on: Sat, 24 March 2018, 17:41:38 »
So you just squirt it in from the top? How do you get it to reach the right part of the stabilizer arms?
Offline MajorKoos
« Reply #3 on: Sat, 24 March 2018, 21:10:33 »
Here's a shot from the bottom
192346-0
and from the top
192348-1
I just put a small blob (half a match head or so) on the purple plastic either side of the exposed bit of wire and let it work itself in.
That grease is quite viscous.
Offline zslane
« Reply #4 on: Sun, 25 March 2018, 11:29:11 »
Ah, got it. Thank you very much for those photos!
Offline zutroy
« Reply #5 on: Fri, 11 May 2018, 09:14:15 »
and from the top
Just wanted to chime in to confirm that this is a great lubing method. I lubed the hell out of the stabs when I opened up my Novatouch to lube the sliders, and I was still getting a lot of rattle from the stabilized keys. I really didn't want to take the board apart again, so I used your method, and the stabilized keys are sounding MUCH better. I guess getting lube on the top and bottom is key (I usually just put a bunch of lube right on the wires when I have the keyboard open).
Thanks for the advice!
