Author Topic: [IC] CHEAP 3D printed Dactyl bases.  (Read 5099 times)
Offline AShifter
« on: Sat, 24 March 2018, 19:01:41 »
Just looking to see if there is any interest in cheap Dactyl frames. I'll make dactyl-keyboard and dactyl-manuform bases for somewhere around $49.99 to $69.99 - just depends on the results I get. Hopefully I'll be able to make some more interesting things in the future, but for now, just reply to this form: https://goo.gl/forms/RQGeCIWErfZrORAu1
Offline thad
Re: [IC] CHEAP 3D printed Dactyl bases.
« Reply #1 on: Sat, 24 March 2018, 19:03:32 »
What kind of printer are you using?
Sent from my SM-G950U using Tapatalk
Offline AShifter
« Reply #2 on: Sat, 24 March 2018, 19:06:10 »
I'll be using my Anet A8 as I don't have access to anything else at the moment. Also, let me know what layer height I should print at - I'm considering 0.3mm and some light sanding followed by baking to get the part stronger.
Offline UsualSuspectXXX
  • (⌐■_■)⊃━☆゚.*・。゚
« Reply #3 on: Sat, 24 March 2018, 20:23:40 »
Yea, I'm interested. Depending on how they come out.
Offline AShifter
« Reply #4 on: Sat, 24 March 2018, 22:51:28 »
I'll be sure to post pictures of the final result once my filament comes in - want to make sure I have some fresh plastic for this. Thanks for your interest!
Offline keebwarrior
« Reply #5 on: Sat, 31 March 2018, 13:43:39 »
I'd be interested in how the base is constructed. Only having a few thin feet will make it unstable. It would be nice for the bases to be angled slightly to make it more ergonomic as well.
