Author Topic: Ergonomic, Bluetooth and cool - need help!  (Read 3264 times)
Offline MC Qwerty
« on: Sun, 25 March 2018, 08:25:23 »
Hey all planning on a new build,
but I am stuck, I trying find a pcb that has a 40-50% layout and fits any of these:
-bluetooth
-split
-40-50% layout
-like a plank
- like jd 40
- looks cool
does'nt have to fill in all those points just sum  ;)
Thanks guys and have a nice day ;D
MC Qwerty
Re: Ergonomic, Bluetooth and cool - need help!
« Reply #1 on: Sun, 25 March 2018, 09:35:52 »
So many conflicting requirements pretty much anything could fit, the Atreus is small, split and looks great to me so maybe try that?
Offline MC Qwerty
« Reply #2 on: Sun, 25 March 2018, 10:05:01 »
MC Qwerty
Offline MC Qwerty
« Reply #3 on: Sun, 25 March 2018, 11:19:46 »
I think the Mitosis looks pretty cool, split bluetooth anyone got one
MC Qwerty
Offline Phenix
« Reply #4 on: Sun, 25 March 2018, 11:28:50 »
Mitosis is NOT bluetooth, it uses Nordic wireless modules: one needs a „special“ USB dongle. Usage with iPads is out of the water therefore :/
Look into the BLANCK - some modded their PLANCK to Feature Bluetooth using a arduino feather.
You should know Software some bit.
If you find (or create ;)) a easy to understand guide more will attempt modding theirs...
Winter is coming.
Offline MC Qwerty
« Reply #5 on: Sun, 25 March 2018, 13:35:35 »
Good idea I am planning on get a plank and possibly a mitosis for a bit of fun (thanks for informing me about the dongle)
MC Qwerty
Offline MC Qwerty
« Reply #6 on: Mon, 26 March 2018, 03:17:56 »
Also thanks for the sugestion suicidal_orange btw
MC Qwerty
Offline joric
« Reply #7 on: Wed, 01 August 2018, 19:11:08 »
It is now: https://github.com/joric/mitosis/tree/devel/mitosis-bluetooth it only needs a firmware update (and only for the right half).
« Last Edit: Wed, 01 August 2018, 20:24:08 by joric »
