Author Topic: What's the name of this set? Can't forget about it after seeing it.  (Read 7909 times)
Offline longface
What's the name of this set?  And how do I find a set for myself?  I saw it several days ago on Deskgram and now I'm not able to get it out of my head.  I guess it is growing inside my brain.
ThinkPads, tennis racquets and now, keyboards
Offline Bambino
  • Suited Up Keycaps
Re: What's the name of this set? Can't forget about it after seeing it.
« Reply #1 on: Mon, 26 March 2018, 17:53:21 »
Maxkey orange on dolch. It's a great one!
Offline longface
« Reply #2 on: Mon, 26 March 2018, 17:57:00 »
Thank you!  I will take a look.
Offline ghostjuggernaut
« Reply #3 on: Mon, 26 March 2018, 17:58:25 »
Another option is Hack'd by geeks in SA.  It was ran in 2015, so would be tougher to find I think.
Offline longface
« Reply #4 on: Mon, 26 March 2018, 18:11:06 »
Hey I think this is the one!  Thanks, although now I realize that it could be hard to find.
I saw a "GMK Skidolcha" set on Originative that is quite similar, but not the same (with a couple of orange keys which I don't want).  And it costs $180.00.
Offline xondat
  • i'm not a star
« Reply #5 on: Mon, 26 March 2018, 18:13:20 »
The picture you linked is the Maxkey set. It's just a copy of Hack'd. Same profile though.
Offline longface
« Reply #6 on: Mon, 26 March 2018, 18:24:49 »
I was not able to find the Maxkey set.  Could you provide a link, or point the direction?  Thanks.
Offline BlindAssassin111
  • I design keyboards and stuff.
    • Viktus
« Reply #7 on: Mon, 26 March 2018, 18:28:41 »
Here you go: https://keyclack.com/product/saMaxKeys1
Offline longface
« Reply #8 on: Mon, 26 March 2018, 18:42:01 »
Got it.  Thank you.
Offline Hyde
  • White Tofu Extraordinaire
« Reply #9 on: Tue, 27 March 2018, 13:27:48 »
Yeah the GMK one is pretty similar but different profile.  GMK is Cherry profile, the one you linked is SA profile.
Which you'll like better is preference, but most would probably find Cherry profile easier to switch to.
Offline PRkeys
« Reply #10 on: Mon, 02 April 2018, 18:28:38 »
If you like that style you may want to take a look at the "DSA Season of the Witch" set currently under development. Will be a wait but is looking so good...
https://geekhack.org/index.php?topic=91813.0
Offline dead_pixel_design
  • IIIV is not a Roman Numeral. Positive Vibes.
« Reply #11 on: Tue, 03 April 2018, 14:09:40 »
Skidolcha is on Md right now
https://www.massdrop.com/buy/gmk-keycap-extravaganza
But will likely not be in stock long.
Offline Out_of_diplomacy
« Reply #12 on: Wed, 04 April 2018, 12:52:28 »
Still available today. Unfortunately Dolch and Miami Nights are already gone
« Reply #13 on: Wed, 04 April 2018, 13:31:24 »
You can still get them on Originative, only a $20 difference
« Reply #14 on: Wed, 04 April 2018, 14:08:01 »
Thank you. I'll check it out
Offline DMacKB
« Reply #15 on: Sun, 08 April 2018, 18:15:54 »
The HUB kickstarter is going to have a sort of inverted take called “skidata”:
Offline PRkeys
« Reply #16 on: Sun, 08 April 2018, 18:58:11 »
Yes! I am in for one of those and a some of their others.
Offline keylabskeycaps
  • KeyLabs Artisans
    • keyLabsKeycaps
« Reply #17 on: Sun, 08 April 2018, 21:04:09 »
Theres a similar gmk set on massdrop right now. Pretty sure its skidolcha. Pretty reasonably priced for a gmk set. I'm itching to pick one up myself.
