Author Topic: DIY case corners  (Read 2276 times)
Offline DonnyD
DIY case corners
« on: Tue, 27 March 2018, 03:48:10 »
Is 1mm radius corners fillet wont be too sharp ? What is corner radius on the keycaps for reference ? Or on other aluminum cases ?
Offline simpe
  • 40 or bust
Re: DIY case corners
« Reply #1 on: Tue, 27 March 2018, 07:04:55 »
I dont think so? i used 2mm on my lasercut topplate and it seemed pretty round to me, so 1 mm should probably be enough. pics for reference.
192548-0
192546-1
« Last Edit: Tue, 27 March 2018, 07:08:33 by simpe »
Efreet 62g filmed lubed T1 w/ epbt shiro/kuro, Planck Healios, LS 62g Zilent,Gherkin 60g Aliaz, NCKB 50% Gateron brown, GH60 Mx brown
Offline DonnyD
« Reply #2 on: Tue, 27 March 2018, 08:40:55 »
I am trying to make as minimal as possible, so 2mm can be too much. Boxy design apeals to me, it looks more modern to me :D Also i am trying to keep case not wider than keycaps, in other word, then viewed from top, case wont be bigger. So 1mm radius should mimic keycap corner radiu better than 2mm.
Much apreciate your help !!
