Author Topic: Help identifying board  (Read 1610 times)
Offline TapewormCommander
« on: Tue, 27 March 2018, 09:27:22 »
Hi everyone,
I've been looking after Focus/Asian 101 layout keyboards (since I'm running Linux full time now), and managed to find this:
https://drive.google.com/file/d/1O9BBEvklZdZTrs_5Sd9dNYeTIoKGn9jN/view?usp=sharing
The author says the following:
"I'm selling 2 Malaysian PC keyboards with a stratified (???) circuit board and arc/spring keys, not like these nowadays that get ruined because of the silver foil (???). Both are from 1996, 100% functioning, and if they get broken, their keys can be replaced (this is where I'm calling BS). They have 'racks' jack."
As you can all guess, I can barely understand what this woman means, thus the deal seems shady, but if she isn't lying, I might buy it.
« Last Edit: Tue, 27 March 2018, 09:29:45 by TapewormCommander »
Offline Blaise170
  • ALPS キーボード
    • XYZ
Re: Help identifying board
« Reply #1 on: Tue, 27 March 2018, 09:29:40 »
Looks like rubber domes to me. I'm thinking she might be talking about foam and foil switches, which are capacitive and use springs under the keys.
« Reply #2 on: Tue, 27 March 2018, 09:38:57 »
I live in Romania, if this helps anyone. (Eastern Europe-only keyboard, maybe?)
Offline Blaise170
  • ALPS キーボード
    • XYZ
« Reply #3 on: Tue, 27 March 2018, 09:43:58 »
Looking at the keycaps, they somewhat remind me of a slider-over-membrane design but I can't be sure. Can you at least get an image of the back? Might be able to tell more if I can see the back, especially if it has a label.
Offline Daniel Beardsmore
  • RIP
    • Boring twaddle
« Reply #4 on: Tue, 27 March 2018, 15:56:17 »
Left: Mitsumi KPQ-E99ZC (or variant thereof)
Right: Chicony KB-5911 (or variant thereof)
Buckling rubber sleeve and rubber dome respectively.
Bore Awards
Offline davkol
  •  Post Editing Timeout
« Reply #5 on: Tue, 27 March 2018, 15:56:24 »
The right one (with winkeys) is almost certainly a Chicony rubber dome.
I'm fairly confident the left one is a Mitsumi with "hybrid" switches (probably rubber sleeve over membrane, but might have a spring instead of the sleeve or foam&foil instead of the membrane).
