Author Topic: Mounting diodes inside switches  (Read 2025 times)
Offline DonnyD
« on: Tue, 27 March 2018, 16:03:36 »
Is this methid good/wont harm diode ? I am doing hand wired built and trying to make as slimm as possible, so putting diodes inside should help.
Offline emenelopee
  • *klomp klomp klomp* I step on your house 🦖
Re: Mounting diodes inside switches
« Reply #1 on: Tue, 27 March 2018, 16:22:33 »
It'll "work", but you stil need to connect the diodes to the switch terminals which will add connections - typical handwires use the diode legs as part of the matrix, which would still sit below the switches. In short, you can do it but I don't think you'll get the benefits you're looking for and you'll be adding complications and potentially more soldered connections. The diodes aren't the things that add any real thickness to the board.
I've seen people squeeze out a mm or two by bending the switch pins, alternatively you could look into the low pro switches.
« Last Edit: Tue, 27 March 2018, 16:24:56 by emenelopee »
Offline Tactile
« Reply #2 on: Tue, 27 March 2018, 18:25:12 »
Why not put the diode inside the switch? Cherry themselves do it this way.
192576-0
« Last Edit: Tue, 27 March 2018, 18:28:24 by Tactile »
REΛLFORCE
Offline DonnyD
« Reply #3 on: Tue, 27 March 2018, 23:56:03 »
Yeah, i realized putting diodes inside switch few minutes after i posted. But i think i will stick to my plan putting diodes inside; ill see how it goes...
