Author Topic: Brown keycap sets  (Read 14179 times)
Offline mudcakehoney
Brown keycap sets
« on: Thu, 29 March 2018, 01:07:10 »
Are there any (pref) GMK sets with dark brown mods?
Ideally with cream alphas as well but that’s not a necessity. Otherwise DSA sets with these colours might work if you can suggest me any. I have SA Chocolatier and SA Flamingo covered for SA profile.
Cheers.
Offline amnesia0287
  • Formerly Amnesia
Re: Brown keycap sets
« Reply #1 on: Thu, 29 March 2018, 03:02:45 »
The only brown GMK set I'm aware of is GMK Mint Chocolate:
That said, I really want to run this at some point:
« Last Edit: Thu, 29 March 2018, 03:05:17 by Amnesia »
Offline Coreda
« Reply #2 on: Thu, 29 March 2018, 04:15:35 »
The Coffee set from a few years ago on KeyPop?
Not sure of the availability nowadays.
« Reply #3 on: Thu, 29 March 2018, 05:35:32 »
I'm a big fan of the 2nd one, I would definitely support it.
« Reply #4 on: Thu, 29 March 2018, 05:38:50 »
Is that GMK?
Either way I like it a lot and would like very smart on a walnut board
Offline pixelpusher
« Reply #5 on: Thu, 29 March 2018, 07:22:30 »
Coffee set is DCS I believe, not cherry profile (hence,  not GMK)
Maybe some day there will be a nice all brown GMK set like retro.  They tried to run GMK retro on Massdrop, but it was met with underwhelming interest and did not reach MOQ.
« Last Edit: Thu, 29 March 2018, 07:26:17 by reececonrad »
Offline Blaise170
  • ALPS キーボード
    • XYZ
« Reply #6 on: Thu, 29 March 2018, 10:32:27 »
I'm pretty sure KeyPop sources their keys from SP, since the profiles generally match. I haven't seen that set in ages though, so I doubt you'd be able to easily find it.
Offline AuthenticDanger
« Reply #7 on: Thu, 29 March 2018, 11:08:39 »
DSA Coffee House might actually run in the next few months. It failed in a previous GB, but they were thinking about trying again IIRC.
F Keys belong on the left.
Offline hervuli
« Reply #8 on: Thu, 29 March 2018, 11:15:53 »
Can confirm Keypop's Coffee was a DCS set. It's also the best-looking brown set I've seen and I'd love to see that colorway run as GMK (or really any Cherry profile, which would basically automatically make it better than SP DCS).
JD40v2 MX Grey | HHKB BKE Heavy | E6-V2 78g Tealios | ZealX60 72g MX Zilent | TGR 910 RE 78g MX Zilent | Singa Vintage MX Black | Octagon V2 MX Grey | Orion V2 MX Clear | Novatouch BKE Extreme
Offline zslane
« Reply #9 on: Thu, 29 March 2018, 13:24:32 »
The Filco SA set is very dark brown in color:
192674-0
SA Retro is a chocolatey brown color:
Offline pixelpusher
« Reply #10 on: Thu, 29 March 2018, 13:45:55 »
I really dig the filco brown.  It's a much shinier finish than other SA sets I have though and always shows a lot of oil.  I find myself wiping the keys a lot.  Still looks nice, though.
Offline captsis
  • Formerly matt2dlg
« Reply #11 on: Thu, 29 March 2018, 18:45:59 »
There was SA Chocolatier
Offline zslane
« Reply #12 on: Thu, 29 March 2018, 18:57:25 »
Yep. The OP mentioned them in the very first post.
Offline jeremyhrvtn
  • keebs cases keysets switches mice trackballs
« Reply #13 on: Tue, 10 April 2018, 10:15:18 »
I'm very in support of this.
I'm constantly looking for brown keycap sets.
« Reply #14 on: Wed, 11 April 2018, 00:18:22 »
dcs coffee
« Reply #15 on: Wed, 11 April 2018, 03:19:03 »
dcs coffee
What’s DCS profile like compared to the big 3?
Offline Blaise170
  • ALPS キーボード
    • XYZ
« Reply #16 on: Wed, 11 April 2018, 08:00:55 »
Offline hervuli
« Reply #17 on: Wed, 11 April 2018, 10:28:23 »
dcs coffee
It's somewhat similar to Cherry but with a more pronounced up-angle on the bottom row, to an extent I find uncomfortable, especially on the spacebar. Caps are also very thin and cheap feeling after being used to 1.5mm thick GMK or high quality PBT caps. The one thing I like about DCS is the texture on the top of the caps, which is nice and rough.
« Reply #18 on: Thu, 12 April 2018, 06:05:55 »
dcs coffee
Thanks, would love to see this run in GMK sometime as mentioned above it might even be a possibility in the near future.. Although the GMK schedule is getting pretty backed up right now
