Author Topic: Pro Micro controller questions?  (Read 2335 times)
Offline MC Qwerty
« on: Fri, 30 March 2018, 09:35:49 »
Hello everyone got some questions about the Pro Micro controller,
I am considering building a gherkin or something which induces a pro micro,
I was wondering though are their any pro micros that have USB C or USB mini?
because I don't enjoy using micro usb as a connector so I was wondering are
their other pro micros that work with these projects?
Thanks for the help
and have a nice week ;)
MC Qwerty
Offline Blaise170
  • ALPS キーボード
    • XYZ
Re: Pro Micro controller questions?
« Reply #1 on: Fri, 30 March 2018, 09:40:01 »
Offline MC Qwerty
« Reply #2 on: Fri, 30 March 2018, 10:11:39 »
Does that work in a pro micro slot?
MC Qwerty
Offline Blaise170
  • ALPS キーボード
    • XYZ
« Reply #3 on: Fri, 30 March 2018, 10:17:55 »
I don't know what a Pro Micro slot is.
Offline TalkingTree
    • My projects
« Reply #4 on: Fri, 30 March 2018, 10:18:12 »
Pro Micro and Teensy 2.0 have different layouts and pinouts so they are not interchangeable. You are to use the controller for which the board is designed to work with. One thing you could do is using a USB Mini-B breakout board but it's honestly not worth it.
Offline Blaise170
  • ALPS キーボード
    • XYZ
« Reply #5 on: Fri, 30 March 2018, 10:30:34 »
Oh that's what he means. You could always but a connector and solder it yourself, though I can't say for sure whether you'd have any issues with connector dimensions. In general USB-C is almost as small as micro though so I think it should work.
Offline MC Qwerty
« Reply #6 on: Fri, 30 March 2018, 11:29:56 »
Cool thanks
MC Qwerty
Offline jimirolln
« Reply #7 on: Fri, 30 March 2018, 13:14:03 »
the proton c is a replacement for the pro micro...it has type c
red it link:  https://www.reddit.com/r/olkb/comments/87uo3l/a_proton_c_companion_for_split_boards/
the smaller is the electron...if you want to do a split build...as opposed to two pro micros
« Last Edit: Fri, 30 March 2018, 13:22:19 by jimirolln »
