Author Topic: Stabilizers for spacebar  (Read 1917 times)
Offline demas
« on: Fri, 30 March 2018, 12:24:25 »
I am changing the keycaps on my keyboard and have a problem with stabilizers on my spacebar (see picture)
On the top is an original keycap, below is the new one.  They looks the same. But looks like the stabilizers can not connect to the slot on the spacebar.  All other keys work fine.
Is there any way to fix it ?
Offline demas
Re: Stabilizers for spacebar
« Reply #1 on: Fri, 30 March 2018, 12:29:36 »
Hmm.... I have added rings on the sides (but not in the middle) and looks like it helps.
Offline nogoodnames444
  • I like keyboards
« Reply #2 on: Tue, 03 April 2018, 00:31:29 »
It might be warped you have to bend it or heat it up so it bends back to normal this only happens with pbt spacebars
