Author Topic: Oh boy, this is an interesting one...  (Read 3251 times)
Offline ch_123
« on: Sun, 11 April 2010, 15:46:36 »
Anyone see this?
Whatever that is, it's not Buckling Springs - the keycaps and the backplate are definitely not from either a Model F or a Model M. The ribbon cables suggest that it's not an F either. I think I'm going to send Brandon an email and find out more...
EDIT: Turns out that Oak Switch Systems was a company that made... that's right - switches. I'm guessing that someone wanted a linear keyboard and IBM obliged. Or maybe it was rubber dome/foam'n'foil? Seems unlikely. Again, an email is needed.
« Last Edit: Sun, 11 April 2010, 16:06:47 by ch_123 »
Offline ch_123
« Reply #1 on: Sun, 11 April 2010, 16:12:03 »
The more I look at it, the weirder it is. The cable is far shorter than other Model Fs. Unlike the buckling spring Model F industrials I've seen, it has feet and no drainage channels/openings near the bottom. Two theories -
A) This thing was just a different revision of the Industrial Model F that was damaged, and some third party vendor retrofitted it with their own keyboard assembly/controller.
B) IBM, for whatever reason, needed to subcontract the manufacturing of these keyboards to a third party. It would explain why the case is completely different to IBM-made industrials, but it would seem unlikely that IBM had such a huge demand for them that they'd need to subcontract them out...
I dunno.
Offline Rajagra
« Reply #2 on: Sun, 11 April 2010, 16:45:58 »
The tilde key looks weird, like it was taken from the top row.
Offline ch_123
« Reply #3 on: Sun, 11 April 2010, 16:51:08 »
The Numpad minus looks very out of place also.
The keycaps remind me of some foam'n'foil keyboards I've seen. My money is on a retrofit...
Offline ch_123
« Reply #4 on: Sun, 11 April 2010, 16:57:15 »
The ones in the Industrial are definitely not normal... too flat and short
Offline D-EJ915
« Reply #5 on: Sun, 11 April 2010, 17:44:53 »
looks pretty cool to me, I like those shorter keys like on the type6/7 and hhkb
Offline ch_123
« Reply #6 on: Fri, 16 April 2010, 04:21:03 »
Oh yeah, I got an email from Brandon a few days back, apparently they had linear switches. I'm still thinking it was a third party refurb.
