Author Topic: Hi from UK  (Read 3734 times)
Offline Out_of_diplomacy
Hi from UK
« on: Sat, 31 March 2018, 13:12:02 »
Hi everyone! Long time lurker here, I will start emptying my wallet soon so might as well introduce myself. Got a Masterkeys Pro l, with brown cherries which give a good clickety clack, but the more I read about this word the more I want to be part of it.
Treat me well,
Cheers
Offline Belfong
Re: Hi from UK
« Reply #1 on: Sat, 31 March 2018, 20:26:14 »
Hi there... the rabbit hole is much, much deeper! Stay away from artisan :)
Re: Hi from UK
« Reply #2 on: Sun, 01 April 2018, 14:14:38 »
Mistakes will be made
Offline PollandAkuma
Re: Hi from UK
« Reply #3 on: Mon, 02 April 2018, 05:38:15 »
Hi person from UK! Have fun!
Sent from my SM-G900F using Tapatalk
Re: Hi from UK
« Reply #4 on: Mon, 02 April 2018, 05:43:33 »
Just make sure they aren't the kind where you buy incompatible stuff - there's nothing worse than waiting for all the parts and them not fitting together!
« Last Edit: Mon, 02 April 2018, 08:10:51 by suicidal_orange »
Re: Hi from UK
« Reply #5 on: Mon, 02 April 2018, 07:52:58 »
Thank you everybody!
Also the captchas to post are terrifying
Offline Blaise170
  • ALPS キーボード
    • XYZ
Re: Hi from UK
« Reply #6 on: Mon, 02 April 2018, 08:17:28 »
They will go away once you have a few posts.
Re: Hi from UK
« Reply #7 on: Mon, 02 April 2018, 08:22:32 »
So glad to read this. Thank you
Offline Belfong
Re: Hi from UK
« Reply #8 on: Mon, 02 April 2018, 10:06:53 »
Is that worse than you have forgotten you bought something because of the rabbit hole you were in?
