Author Topic: Meira users with feather 32u4 MCU, bluetooth function fixed. Needs some testing.  (Read 1413 times)
Offline hgoel89
u/MrMontgomery on reddit had issue with his feather32u4, so I check the qmk branch and realize that there was some correction required to make the bluetooth work correctly.
I have made the required changes in repo here.
The bluetooth should be working properly now.
Use make meira:default as default folder is set to featherble config files
DO NOT FLASH IF YOU GET FILE TOO BIG ERROR
« Last Edit: Tue, 03 April 2018, 09:03:07 by hgoel89 »
