Author Topic: [IC] GMK Wāpuro  (Read 63669 times)
Offline oh_chesteroni
Re: [IC] GMK Wāpuro
« Reply #50 on: Thu, 05 April 2018, 03:25:33 »
Yes would love this with the new saga green rama
You hit the nail on the head with this one, friend. Exactly what I was thinking!
Sent from my SM-G900W8 using Tapatalk
Offline kevinzavier
Re: [IC] GMK Wāpuro
« Reply #51 on: Thu, 05 April 2018, 18:09:49 »
In for a set
Offline typischt
Re: [IC] GMK Wāpuro
« Reply #52 on: Fri, 06 April 2018, 08:03:43 »
Really nice looking set!
Maybe it should be clear already and I’m no realizing it, but could you translate the novelties? Wouldn‘t want to put those on a board without knowing at all what they mean..
Offline Kevadu
Re: [IC] GMK Wāpuro
« Reply #53 on: Fri, 06 April 2018, 11:51:16 »
Skipping keys that don't need translating:
R1: Power/Charge, Insert, Delete
R2: (same except with a blank)
R3: Newline
R4: Katakana, Hiragana, Katakana, Hiragana (they're two Japanese character sets so presumably it would be for switching between them)
R4: Alphanumeric (i.e., ASCII), Alphanumeric, Menu, Function, Function, Alphanumeric
R4: Alphanumeric, Alphanumeric, Katakana, Hiragana, Function, Menu (with Help written small in the corner)
Offline MacGruber117
Re: [IC] GMK Wāpuro
« Reply #54 on: Fri, 06 April 2018, 13:04:47 »
R3: Newline
If you check out the link from r/mk, where I got help with the translations, you can see where those keys are located in the original set
I want to buy your ETF and Garbo Pusses. PM me
Offline typischt
Re: [IC] GMK Wāpuro
« Reply #55 on: Sun, 08 April 2018, 05:35:24 »
R3: Newline
Ah perfect, thanks a lot guys!
Offline croa
Re: [IC] GMK Wāpuro
« Reply #56 on: Sun, 08 April 2018, 15:39:21 »
Hiragana me daddy.
Offline merutz
  • @merutz
Re: [IC] GMK Wāpuro
« Reply #57 on: Mon, 09 April 2018, 10:29:32 »
dope set  :thumb:
QFR R-i/DSA Dolch   |   MX Master
     + yellow Esc
Offline Tyson
Re: [IC] GMK Wāpuro
« Reply #58 on: Wed, 11 April 2018, 10:01:10 »
I'm all in on this, this is the true cyberpunk keyset if you think about it. This keyset fits in with the world of Blade Runner and Terminator more than GMK Laser does. Hopefully this thing comes out!
Offline fouras
Re: [IC] GMK Wāpuro
« Reply #59 on: Wed, 11 April 2018, 18:18:19 »
Love it. Easily my favorite set since Laser. Could you swap the HHKB backspace from an arrow to text, though? Having one cap be icon-only always bugs me. The spacebars kit could use four convex 1u caps for ortho too.
« Last Edit: Wed, 11 April 2018, 18:22:30 by fouras »
Offline iliketimex
Re: [IC] GMK Wāpuro
« Reply #60 on: Tue, 17 April 2018, 00:29:28 »
I like the neutral gray (more like 2B) of the first photo a lot more than CC color gray of the second.
Offline hineybush
  • student of error
    • hineybush keyboards
Re: [IC] GMK Wāpuro
« Reply #61 on: Tue, 17 April 2018, 00:58:01 »
Yeah, 2B is "cooler" and would match N9 better imo. On the other hand, BV is a warmer version of N9 and would pair nicely with CC.
Ref pic: I tossed a few other colors in for reference too. N6 might work for the yellow sublegends, but it's def not true to the original. AE looks like a good fit for the green pad printed legends.
« Last Edit: Tue, 17 April 2018, 09:37:00 by hineybush »
Offline gutsack
Re: [IC] GMK Wāpuro
« Reply #62 on: Tue, 17 April 2018, 02:20:38 »
My preference would also be for cooler tones. Brown gray is harder to match up nicely with non-black cases. Also, in the two pictures from OP to start off the IC, the first was a more color-accute capture of the Sony hardware and the second was clearly taken in warm lighting... The colors for these caps seems to have been taken from the over-warm photo. I don't think it needs to go all the way toward cool gray, but do agree 2B is preferable.
Offline DJSwayde
Re: [IC] GMK Wāpuro
« Reply #63 on: Tue, 17 April 2018, 08:48:55 »
Any chance you do Hiragana legends on the mods in the darker color and not the orange color?
60%: CannonKeys Bakeneko60
BUILD 1: Black | FR4 plate | Cherry Vintage Blacks & Vintage Grey (TX 55g springs) | Cherry G80-3000LPCXY-2 keycaps
BUILD 2: Black | 1upkeyboards π60 (pi60) PCB | 1upkeyboards FR4 plate | Akko Rosewoods | HammerWorks CRP R6 Egyptian Alphas kit & CRP R7 kits (40%, 60%, Spacebars, Stepped Modifiers) keycaps
 | GEONWORKS Frog Mini
Silver | HHKB | 4pplet Steezy60 (Alps) PCB | Custom SS plate | Alps SKCL Yellows | Canon S-14 & S-16S keycaps
| GEONWORKS LAUNCHER60
Silver | Custom PCB | Custom SS plate | Alps SKCL Creams | C.Itoh CIT224F & IBM 5140 keycaps
| LSJ Ares
Silver | Custom PCB | Custom SS plate | Alps SKCL Browns & SKCL Amber | IBM Multistation 5556-CC1 (TW) & P70 (ANSI-US, 06-89) keycaps
 | LZ CLS h
Silver | Custom PCB | Custom SS plate | Alps SKCM Creams | MET Micro Officer 6000 (R315-00) & Zenith Data Systems TurbosPORT 386 keycaps
| MONOKEI Kei R1
Standard Red | Aluminum plate | Cherry Vintage Blacks & Vintage Grey (TX 55g springs) | Cherry G81-1291SAW & G81-3090SAQ (Schneider) keycaps
| SINGAKBD Unikorn R1
Black | Black aluminum plate | Cherry Retooled Blacks (TX 60g springs) | G80-3485LWNUS (Das Keyboard II) keycaps
| Wangus x KEZEWA Snake60 R2
Silver (re-anodized hot pink) | WKL | Custom PCB | Custom SS plate | NMB "Space Invader" (White one-eye linear [fourth generation]) | NMB RT-101 (NCD) keycaps
 | Weaston GSKT-00-Z
Silver | AEK HHKB | Aluminum plate | Alps SKCL Greens | Apple Extended Keyboard II (M3501, Taiwanese) & Standard Keyboard (M0116, US) keycaps
Pad: KBDFans KBDPAD MKII
Black | FR4 plate | Cherry Vintage Blacks (TX 60g springs) | Cherry G80-3485LWNUS (Das Keyboard II) keycaps
| KBDMania KMAC Pad
Titanium grey | Aluminum plate | Cherry Vintage Blacks (TX 60g springs) | Cherry G81-3090SAQ (Schneider) keycaps
| Leopold FC 210TP
White | Custom PCB | Custom SS plate | Alps SKCL Compact Greens & Alps SKCL Browns | C.Itoh CIT224F keycaps
| Momokai Aurora
Cherry Vintage Blacks (TX 55g springs) | Cherry G80-3000LPCXY-2 keycaps
Topre: PFU Ltd. HHKB Pro 1 (PD-KB300BN)
hasu Alt USB controller | Topre Realforce 91UDK-G (NG02B0) & Realforce 103UB (SE42B0) keycaps
| PFU Ltd. HHKB Pro 2 (PD-KB400B)
hasu Alt Bluetooth controller | Purple sliders | 35g domes | Stock & Topre Realforce Taiwanese kit (dark gray) keycaps
| PFU Ltd. HHKB Pro 2 Type-S (PD-KB400WS)
4pplet SHKB Lite controller | 25g domes | Topre Realforce 87UW55 (SE08T0), Realforce 91UW (NE0100), Realforce Taiwanese kit (white) keycaps
| Topre Realforce 23U (WC0100)
Cipulot EC23U PCB | Purple sliders | SS plate (modified to allow for 24U) | 25g domes | JUKI Celavi keycaps
 | Topre Realforce 87UW (SE08T0)
Purple sliders | 30g domes | Sony BKE-9400A, MKS-8050, PVE-500, stock keycaps
| Topre Realforce 91 (NE0100)
Cipulot RF R1 8-9Xu PCB | 30g domes | JUKI Celavi & Topre Realforce 108UG-HiPro (YK0100) keycaps
Other: Apple Desktop Bus Keyboard (C658-4081) (CA)
Alps SKCM Oranges & SKCL Lock Cream
| Apple M0110A (US)
Beige | Vortex ViBE (US) (case installed inside) | Custom PCB | Custom SS plate | Alps SKCM Blues | Hewlett Packard HP Portable Vectra CS (US) & R/332 Instrument Controller (US) keycaps
| KUL ES-87
Black | Keygeek Su Color V2s (45g) | MW Heresy (with Gluttony & Envy kits) keycaps
| Zuoya HE30
Black | Hotswap: Keytok Novas / Wooting Lekker Tikken Mediums | Ranked POM keycaps
Collection
Re: [IC] GMK Wāpuro
« Reply #64 on: Tue, 17 April 2018, 22:02:36 »
Not quite following what you mean
Offline TheDankMatter
  • Ladies & Gentlemen, We Are Floating In Space.
Re: [IC] GMK Wāpuro
« Reply #65 on: Thu, 07 June 2018, 04:53:24 »
When this?
Offline JJ
Re: [IC] GMK Wāpuro
« Reply #66 on: Thu, 07 June 2018, 04:55:02 »
YESS gimme weeb
Offline sujikinen
Re: [IC] GMK Wāpuro
« Reply #67 on: Sun, 10 June 2018, 06:52:33 »
nice work!
if DC kit happens anyway,I will buy all kits to support it.
Offline Jacob4341
Re: [IC] GMK Wāpuro
« Reply #68 on: Sun, 10 June 2018, 08:12:28 »
I love this set and would have to get the novelties!
Offline pikku-allu
  • IG: @kinnalek
Re: [IC] GMK Wāpuro
« Reply #69 on: Sun, 10 June 2018, 14:25:24 »
Looks awesome! Would be more like a display set but still. Also, the spacebar kit could offer much better compatibility for split spacebar boards by simply adding a 1.25u blank.
Offline Zeroblade
    • Twitter
Re: [IC] GMK Wāpuro
« Reply #70 on: Wed, 27 June 2018, 10:47:58 »
Okay wow this is really cool. And the base kit already has everything I need! (yay for standard layouts)
Offline mircodezorzi
Re: [IC] GMK Wāpuro
« Reply #71 on: Sat, 11 August 2018, 08:20:31 »
The keyset looks amazing, as a Dvorak-Ergodox user I might have to spend more than I'd like to, but for a set like this I'm 100% on board.
Offline oldcat
  • 65% is Life
Re: [IC] GMK Wāpuro
« Reply #72 on: Sat, 11 August 2018, 19:18:04 »
great! Could we have alpha without Japanese characters? Thanks so much
Offline switchnollie
  • sleever supreme
  • greyhat co-leader
Re: [IC] GMK Wāpuro
« Reply #73 on: Sat, 11 August 2018, 20:59:22 »
That would essentially make the set Dolch & use less inspiration from the Sony board though.
Offline hineybush
  • student of error
Re: [IC] GMK Wāpuro
« Reply #74 on: Sat, 11 August 2018, 22:58:13 »
yeah it'd literally be dolch at that point lol
i still want this set
Offline Kallus
Re: [IC] GMK Wāpuro
« Reply #75 on: Sun, 12 August 2018, 12:42:50 »
I would love to have nordic keys
Offline Kawamashi
Re: [IC] GMK Wāpuro
« Reply #76 on: Mon, 13 August 2018, 15:20:21 »
100% in !
Offline rioc
Re: [IC] GMK Wāpuro
« Reply #77 on: Tue, 11 September 2018, 10:19:32 »
when is this happening? I need it :)
also: it needs 1.25U and 1.5U "NO" and "YES" keys in the novelty kit ;)
« Last Edit: Tue, 11 September 2018, 10:21:10 by rioc »
Offline 8BitDuck
Re: [IC] GMK Wāpuro
« Reply #78 on: Tue, 11 September 2018, 11:05:28 »
That'll be a yep from me on this set.
Offline yinzer
  • I'm new around here ... please don't notice.
Re: [IC] GMK Wāpuro
« Reply #79 on: Wed, 12 September 2018, 10:24:31 »
Missed this set when it was first proposed months ago. I like some of the proposed color changes to make it slightly different from just "weeb dolch," but maybe that's not a bad idea.
If this set is going to exist, I have thoughts on the ergodox kit:
1) If the mod color remains N9, you probably won't need to have (or be able to) this kit made. It already exists. Terminal's N9 ergodox kit has already had two rounds and there will be some in stock. They even come with Skidata orange accent keys.
2) While probably enormously expensive, it might be cool to see if it would be possible to get symbols or hirigana legends on the the ergodox mods. While not necessarily my jam, people seem to like the idea of somethingon their mods, like with Space Cadet's Assembly. It would be a cool way for this set to stand out from the existing N9 kit. Though, it might be cost prohibitive.
Offline LightningXI
  • PPD
    • ArtisanMacro
Re: [IC] GMK Wāpuro
« Reply #80 on: Sun, 16 September 2018, 16:40:05 »
Still hoping this will happen.
Offline rioc
Re: [IC] GMK Wāpuro
« Reply #81 on: Mon, 17 September 2018, 02:45:28 »
Me too! This will be the perfect, TRUE cyberpunk set and perfect match with the HB-85 Board :)
Offline SBN
Re: [IC] GMK Wāpuro
« Reply #82 on: Sat, 27 October 2018, 17:27:45 »
Looks really nice! Any updates on this?
Offline rioc
Re: [IC] GMK Wāpuro
« Reply #83 on: Sat, 27 October 2018, 18:25:43 »
yeah, already ordered a silver & gray HB85 for this set to go on ;)
« Last Edit: Sun, 28 October 2018, 08:45:48 by rioc »
Offline longsock
Re: [IC] GMK Wāpuro
« Reply #84 on: Sun, 28 October 2018, 07:33:19 »
 im so in for tis
Sent from my SM-G965F using Tapatalk
QXP | HHKB Pro 2
Incoming: Duck Viper V3
Offline theoriginal123123
Re: [IC] GMK Wāpuro
« Reply #85 on: Thu, 14 February 2019, 05:21:17 »
Is this still a thing? In for this set!
Offline mimalik
Re: [IC] GMK Wāpuro
« Reply #86 on: Thu, 14 February 2019, 06:50:04 »
Numpad split???
Offline gnhuy91
Re: [IC] GMK Wāpuro
« Reply #87 on: Thu, 14 February 2019, 08:01:37 »
would love to see this set move to GB phase, this colorway is hawt
Offline Korseir
Re: [IC] GMK Wāpuro
« Reply #88 on: Sun, 17 February 2019, 01:07:27 »
This set looks really nice! I think there should be a R3 1.75u Orange Enter key (the only enter key in the base kit that doesn't have an orange version)
Offline vicissitude
Re: [IC] GMK Wāpuro
« Reply #89 on: Sun, 17 February 2019, 05:55:02 »
I love English with Hiragana.
It's so special.
The orange keycaps are also nice.  :thumb: :thumb:
Offline pan
    • Massdrop
Re: [IC] GMK Wāpuro
« Reply #90 on: Thu, 21 February 2019, 18:49:58 »
I'm excited for this to happen!
Definitely down to join the GB when it all comes through  :D
RAMA U80-A Milk, Holy Panda, GMK9009
Waiting on:
G60 NCR
Offline ArchDill
Re: [IC] GMK Wāpuro
« Reply #91 on: Thu, 21 February 2019, 19:17:39 »
This is pretty rad
Offline wellbeing44
  • kebord good kebord fun yum yum
Re: [IC] GMK Wāpuro
« Reply #92 on: Sat, 23 February 2019, 21:54:38 »
Is OP still on this?
Offline Korseir
Re: [IC] GMK Wāpuro
« Reply #93 on: Mon, 25 February 2019, 09:45:14 »
where is the Orange R3 1.75 enter key at?
Offline Sintpinty
  • Carbon Based Life Form
    • My Roblox Profile
Re: [IC] GMK Wāpuro
« Reply #94 on: Mon, 25 February 2019, 10:15:19 »
This looks like a nice set with a great choice of color. :)
Just my thoughts
Offline harlekein
Re: [IC] GMK Wāpuro
« Reply #95 on: Mon, 25 February 2019, 10:21:48 »
Hiragana + novelties would make a great ortho kit.
Offline 8BitDuck
Re: [IC] GMK Wāpuro
« Reply #96 on: Mon, 11 March 2019, 17:10:03 »
Is anything happening with this kit? I'm really interested.
Offline Shenpai
  • always found
    • padoru
Re: [IC] GMK Wāpuro
« Reply #97 on: Mon, 11 March 2019, 19:17:29 »
hot
Nunu | KR FC660C
Offline equalunique
Re: [IC] GMK Wāpuro
« Reply #98 on: Wed, 27 March 2019, 14:59:17 »
I am in for every single one of these kits.
First time I've ever seen a dvorak/colemak kit with katakana sublegends.
Dreaming of outfitting a 1800-layout keeb with the base+dc+novelty kit & a nyquist/sp50 with the hiragana+ergo/planck kit.
Sent from my LG-H918 using Tapatalk
Offline equalunique
Re: [IC] GMK Wāpuro
« Reply #99 on: Wed, 27 March 2019, 15:00:44 »
Great minds think alike
