Author Topic: HHKB S Adjustable Feet Ping (Update: not actually feet)  (Read 2044 times)
Offline ubslimpinn
« on: Tue, 03 April 2018, 17:24:57 »
Update: Well, it looks like I was wrong, it wasn't the feet after all. It just happens to be most of, and only, the keys closest to the feet--when I took off the bottom of the case the noise was still there when the keys were pressed.  I suppose I just have the dreaded HHKB switch spring ping on a few of my switches...
When keys closer to the adjustable feet are pressed (1, w) the case makes a noticeable pinging sound. Further keys mean fainter sound. The noise comes from some sort of spring in the feet. I initially thought it was the keys or springs but I have ruled that out.
This happens whether the feet are extended are not. It also happens when the case is tapped on. And it happens regardless of surface.
Anyone else have this problem? Any fixes? I have already realigned the case as carefully as possible. I actually don’t remember having this problem before I did, but I might have. Perhaps someone can try their hhkb to see if they have a similar problem.
« Last Edit: Wed, 04 April 2018, 01:16:13 by ubslimpinn »
Offline Tactile
Re: HHKB S Adjustable Feet Ping
« Reply #1 on: Tue, 03 April 2018, 19:50:29 »
Don't remember my Type S doing this when I had it & my non Type S I'm using right now doesn't do that with the legs folded, short leg out or long leg out (who would use a HHKB with the long legs extended?). There are screws in those corners near the legs - are the screws tight?
REΛLFORCE
Offline ubslimpinn
« Reply #2 on: Tue, 03 April 2018, 20:46:35 »
Thanks for checking and letting me know. I’ve got the screws very tight at the moment. Actually thought they might be too tight and loosened them but that didn’t fix anything. I might take the case off yet again to see if I can figure something out.
Offline Sup
Re: HHKB S Adjustable Feet Ping (Update: not actually feet)
« Reply #3 on: Thu, 05 April 2018, 05:29:36 »
you would need to remove the PCB aswell unscrew it. Just remove the dome and spring and place it back it like it was that is the fix normally.
current
Coming soon
