Author Topic: [GB] GMK Screw-in Stabilisers Group Buy  (Read 12718 times)
Offline Mechboards
  • Mechboards UK
    • Mechboards
« on: Thu, 05 April 2018, 05:25:41 »
Hello all!
We're running a GB for GMK Screw-in Stabilisers (to also restock the store)
193128-0
£11.99 + postage = 1 Spacebar of your chosen size + 7 x 2u stabilisers. 60% Set for £3 less.
They will also come with washers to stop shorting!
Should ship end May as GMK are pretty quick at shipping stock. - Shipping worldwide
(Note, 7u wires are delayed until start of June.)
GB LINK
David
« Last Edit: Tue, 17 April 2018, 06:04:08 by Mechboards »
Offline Signature
  • master of puppers
  • * Moderator
  • snoozing
Re: [GB] GMK Screw-in Stabilisers Group Buy
« Reply #1 on: Thu, 05 April 2018, 12:33:39 »
Approved
Offline pr0ximity
« Reply #2 on: Thu, 05 April 2018, 12:40:32 »
Do you have a pic of the washers by chance? Curious what they look like, does GMK provide them or are you sourcing them seperately?
Offline oluigenuma
« Reply #3 on: Thu, 05 April 2018, 13:00:36 »
Joined. Thank you!
Offline Mechboards
  • Mechboards UK
    • Mechboards
« Reply #4 on: Thu, 05 April 2018, 14:44:00 »
We pack these with them - https://uk.rs-online.com/web/p/sealing-washers/0528154/?searchTerm=M2+Plain+Nylon+Sealing+Washer%2C+0.8mm+Thickness
Offline pr0ximity
« Reply #5 on: Thu, 05 April 2018, 17:31:34 »
Good to know, thanks!
Offline fcoury
« Reply #6 on: Fri, 06 April 2018, 16:03:52 »
Do you have a rough estimate of how much it would be to ship let's say 10 6.26u TKL kits to Brazil? I might have people here interested.
Offline Mechboards
  • Mechboards UK
    • Mechboards
« Reply #7 on: Sun, 08 April 2018, 14:05:12 »
Hey email us and I'll get back to you :) info@mechboards.co.uk
Cheers
Offline Mechboards
  • Mechboards UK
    • Mechboards
« Reply #8 on: Wed, 11 April 2018, 05:01:58 »
30 Sets purchased
Offline Dreamre
    • kbdlife
« Reply #9 on: Wed, 11 April 2018, 22:58:53 »
Are you able to lower the declared value of the items when shipping to Canada?
Offline Mechboards
  • Mechboards UK
    • Mechboards
« Reply #10 on: Thu, 12 April 2018, 08:13:41 »
Yea, we can do that :)
Offline phorx
  • ¯\_(ツ)_/¯
« Reply #11 on: Thu, 12 April 2018, 08:41:56 »
I'm not very familiar with GMK Stabs... How do they compare with others like genuine cherrys or Zeals?
Offline enrique.aliaga
« Reply #12 on: Thu, 12 April 2018, 08:59:21 »
I just ordered a set! :)
I'm curious, though... Would I be able to replace the stock Pok3r stabilizers with these? I think the Pok3r (non-backlit) uses plate-mount Cherry-style stabilizers. What do I need to get in order to replace them?
If the stabs in this GB do not serve my purpose, it's no problem. It'll be good to have them for future projects.
Offline Chimera
« Reply #13 on: Thu, 12 April 2018, 09:00:36 »
What shipping method should we pick if we are in the US? Any idea how much additional shipping would be for that?
Offline Anakey
« Reply #14 on: Thu, 12 April 2018, 09:02:34 »
These stabs are PCB mount so they can only be used in PCBs that support them. So you would only be able to replace plate mount stabs with other plate mount stabs on your Pok3r
Offline xondat
  • i'm not a star
« Reply #15 on: Thu, 12 April 2018, 09:05:34 »
These are Cherry, just that GMK sells them so it's easier to call them GMK since the source is verified as being good.
Offline Chimera
« Reply #16 on: Thu, 12 April 2018, 09:10:27 »
Glad you posted this, my next build is plate mount and i almost ordered without knowing.
Offline sorijealut
    • steam
« Reply #17 on: Thu, 12 April 2018, 09:34:35 »
I'm having trouble checking out with paypal atm, probably a temporary thing.
Will try again.
Offline KaosJ
« Reply #18 on: Thu, 12 April 2018, 09:40:32 »
Joining in the weekend  :thumb:
Best stabs so far.
Offline Mechboards
  • Mechboards UK
    • Mechboards
« Reply #19 on: Thu, 12 April 2018, 10:03:57 »
Will try again.
PM me if you're still having issues.
They are seen as the best option :)
They are £2.50 for US/CA shipping.
Offline sorijealut
    • steam
« Reply #20 on: Thu, 12 April 2018, 10:33:49 »
Just got it to go through (in the US). Thank you!
Offline buzzking00
« Reply #21 on: Thu, 12 April 2018, 20:48:27 »
In for my next build!
Offline phorx
  • ¯\_(ツ)_/¯
« Reply #22 on: Sun, 15 April 2018, 12:44:03 »
In for a couple sets.  Pricing and shipping both seem very respectable.
Offline Lansky
  • Realest motherthocker
« Reply #23 on: Tue, 17 April 2018, 05:24:21 »
Also in for a couple of these!
Offline blighty
« Reply #24 on: Tue, 12 June 2018, 15:39:04 »
Is there an update on the 7u wire orders?
LZ ergo (MX silent red) | JER - A06 (MX silent black-red springs) | Duck Lightsaver V2 (MX red) | Duck Octagon V2 (gateron clear) (lifted pads) | Duck Orion V2 (gateron red) | TKC 1800 (gateron silent reds) | Mistel MD770 (MX red with GMK silencing clips) | Realforce R2TSLA-US4-IV | Realforce R2TLSA-US4-BK | TX 75 (gateron clear) | KBDFANS 75 ("vintage" MX blues) | Kinesis Freestyle Pro (MX red) | MS Surface Ergonomic | MS Natural Ergonomic Keyboard 4000 | Filco Majestouch 2 TKL (MX black) | Phantom (Filco case) ("vintage" MX blacks | Spr1t 75% PCB x 2 (MX black and gateron clear) | Cherry G80-1865 (MX browns with black springs)
Offline Lansky
« Reply #25 on: Wed, 13 June 2018, 02:39:02 »
I contacted Mechboards two days ago and got the following reply:
We're just waiting on GMK to ship them out to us. They said they're
under a heavy work load at the moment which is causing a delay. Their
current estimate is mid June, which should be soon. Hopefully we can
have them within the next 7-10 days.
Offline xondat
  • i'm not a star
« Reply #26 on: Wed, 13 June 2018, 07:16:33 »
Also want to make sure this is seen:
https://mechboards.co.uk/were-moving/
Mechboards is moving office this month. Any orders made before the 12th of June will be packed and sent. Any orders after that will be delayed until we’re settled in, which may be 1-2 weeks. Thanks!
Probably won't overlap though.
« Reply #27 on: Wed, 13 June 2018, 14:28:57 »
Sweet; going to join.
Offline theillumedpanda
  • Don't point that gun at me - I'm an unpaid intern!
« Reply #28 on: Wed, 13 June 2018, 15:14:28 »
Are you going to sell those screw-in stabs after the GB has been fulfilled?
Offline Mechboards
  • Mechboards UK
    • Mechboards
« Reply #29 on: Wed, 20 June 2018, 06:22:55 »
Hey all - sorry for the delay!
GMK are only just getting round to sending us our order. So once it's received we'll go through all orders ASAP and get them out to you all!
Cheers for being patient.
