Author Topic: Need help with rotary encoder code in QMK  (Read 2524 times)
Offline confusedtapeworm
« on: Thu, 05 April 2018, 18:05:51 »
Code: [Select]
void matrix_init_kb(void) {
    DDRB &= ~(1 << 1); // Rotary input A -> Pin B1
    //PORTB |= (1 << 1); // Pull-up pin A
    DDRF &= ~(1 << 7); // Rotary input B -> Pin F7
    //PORTF |= (1 << 7); // Pull-up pin B
void matrix_scan_kb(void) {
    rotaryA = (PINB & (1 << 1)); //read inputs from both pins
    rotaryB = (PINF & (1 << 7));
    if ((PinALast == 0) && (rotaryA == 1)){ //compare current and previous states of pin A
        if (rotaryB == 0){
            register_code(KC_VOLU); // do ****
            unregister_code(KC_VOLU);
        else {
            register_code(KC_VOLD);
            unregister_code(KC_VOLD);
    PinALast = rotaryA;
This is the code I have. The exact same code runs perfectly fine on Arduino Micro when I use digitalRead or whatever instead of the direct bit manipulation stuff. I'm probably missing something but I can't tell what. Are my bit manipulations wrong? Am I trying to use forbidden pins? What's the deal here?
Appreciate all the help.
Offline senso
Re: Need help with rotary encoder code in QMK
« Reply #1 on: Fri, 06 April 2018, 05:29:51 »
If you want to compare with 0 and 1 you need to shift right the results of the rotaryA by 1, and the rotaryB by 6 if I'm not mistaken.
Because you are reading PORTF7 you dont get a 0 or a 1, you get 0b10000000 or 0b00000000, or in decimal 128 or 0.
And PORTB1 gives you 0b00000010 or 0b00000000, or in decimal 2 or 0.
