Author Topic: Can someone ID this pls if itll fit.  (Read 4851 times)
Offline serec
« on: Fri, 06 April 2018, 05:00:37 »
Any idea if these caps will fit on topre or MX? Before I go jump on it. Can seem to find anything on the net.
https://imgur.com/a/GCwG8
Offline AMongoose
  • happy workman user
Re: Can someone ID this pls if itll fit.
« Reply #1 on: Fri, 06 April 2018, 08:30:01 »
It's a canon CanoWord alfa 5 super.
Offline serec
« Reply #2 on: Fri, 06 April 2018, 09:23:03 »
I mean will it fit topre or mx? Like other electric type writer
Offline AMongoose
« Reply #3 on: Fri, 06 April 2018, 09:24:38 »
kinda hard to see from that pic, could you post a picture of the underside of the caps next to a ruler?
Offline Blaise170
  • ALPS キーボード
    • XYZ
« Reply #4 on: Fri, 06 April 2018, 10:13:42 »
As I noted on Deskthority:
Your guess is as good as mine. I'd say based on my experience with Japanese keyboards that this is either:
  • Rubber dome (most likely I think)
  • Alps
  • NEC
I highly doubt this to be MX compatible as Cherry was not at all common on vintage Japanese computers.
Offline serec
« Reply #5 on: Fri, 06 April 2018, 10:51:23 »
  • Alps
  • NEC
Cant take a pic since i havent bought it yet. Just wanna make sure if itll fit anything before buying it hehe
Offline Blaise170
  • ALPS キーボード
    • XYZ
« Reply #6 on: Fri, 06 April 2018, 10:54:09 »
Totally get it, though it's going to be really hard to say. Based on the LED placement, it doesn't look like Alps or Cherry, NEC seems unlikely since it's a Canon product, and that leaves very few other switch types that could have been used. I'm heavily leaning towards rubber dome though I'm not positive either way. The LED placement is actually more reminiscent of a foam and foil board but foam and foil is also pretty uncommon on Japanese boards.
Offline serec
« Reply #7 on: Sun, 08 April 2018, 23:03:39 »
So theres no chance that this will be like the ones on a brothwr keyboard that fits a topre?
Offline Blaise170
  • ALPS キーボード
    • XYZ
« Reply #8 on: Mon, 09 April 2018, 07:52:57 »
It might be, but I'm not familiar with the Canon CanoWord.
