Author Topic: CS:GO ASIIMOV KeyCaps  (Read 12590 times)
Offline Mngo
« on: Sat, 07 April 2018, 04:31:53 »
I'm a Chinese senior high school Student, for sure my English is poor.So if there're any mistake in my description,you could tell me,THX.
This design inspired by CS:GO ASIIMOV skin.
This pattern is very complex, so I choose the sublimation PBT.
I'm sorry I don't know how to add pictures(Can someone tell me?)......Touble you go to this site to see the design......So sorry.
https://www.zfrontier.com/post/detail/6004
Offline Mngo
Re: CS:GO ASIIMOV KeyCaps
« Reply #1 on: Sat, 07 April 2018, 04:36:11 »
This design is inspired by CS:GO ASIIMOV skin.
The pattern is very complex, so I choose the sublimation PBT.
Offline dvorcol
  • Discord: dvorcol_5071
« Reply #2 on: Mon, 07 April 2025, 01:02:21 »
Geekhack won't display .WEBP image files, so that might be why you are having trouble.
I put a .PDF of your picture in postimage to get a URL link. Then I put that link in this message with img commands at the front and back. Like this except with [ ] instead of ( )
(img)https://i.postimg.cc/6tV5ZW4y/Asiimov-base.png(/img)
If you look at the exact text of this message (for example by using Quote), note that Geekhack automatically added image size. You will see (img width=640 height=XXX) even though I only typed (img)
If you want a different size, change the value of one dimension and delete the other one, for example (img width=400)
Geekhack automatically calculates the other dimension to keep 1:1. Whenever you revise your post with a new picture link, delete one or both dimensions or the new picture will probably be stretched.
I hope this is helpful!
