Author Topic: [GB] LZ GH V2 : [Completed]  (Read 177248 times)
Offline MajorKoos
  • 1 life please. Extra large.
Re: [GB] LZ GH V2 : Shiped 99%
« Reply #300 on: Wed, 19 September 2018, 12:19:54 »
Where can I find "The QMK firmware includes a setup script to install all the common arduino drivers and firmware flashing tools"?
https://github.com/qmk/qmk_firmware
and for the curious - https://github.com/leeku11
« Last Edit: Wed, 19 September 2018, 12:42:56 by MajorKoos »
Offline dorf
  • divine creator
« Reply #301 on: Wed, 19 September 2018, 13:24:59 »
This is starting to get helpful.
Do we really need to install the whole build environment just to use JigOn?
Can we pinpoint the specific driver/config instead of bloating our computers?
Offline MajorKoos
« Reply #302 on: Wed, 19 September 2018, 14:34:15 »
You don't need any additional tools or drivers to use JigOn - it communicates with the keyboard via the same HID protocol as your mouse so it's plug and play.
If you're not programming the MCU via the ISP header forget about the QMK tools for now - you don't need them.
I've got half a dozen jigon keyboards of various shapes running JigOn_170419 (because the PCB's follow a spec and store the settings in eeprom so they don't each need custom firmware).  Sometimes I get the issue where the app won't connect, and when that happens I change ports on my hub (USB 3).  I've had the same problem at times with QMK and bootmapperclient based keyboards too so I suspect it's more of a windows USB thing than a JigOn thing.  Doesn't happen often enough for me to want to do anything about it.
Offline dorf
  • divine creator
« Reply #303 on: Thu, 20 September 2018, 01:09:17 »
So how come I cannot get the automatic highlighting to work? I have to manually highlight the key I want to reassign.
Offline OracleKev
« Reply #304 on: Thu, 20 September 2018, 02:07:33 »
Did you try Keyboard | Connect (dialog box saying "Connected" should pop up)?
Offline dorf
  • divine creator
« Reply #305 on: Thu, 20 September 2018, 02:29:01 »
Yes. Otherwise it’s not possible to reassign keys.
Offline OracleKev
« Reply #306 on: Thu, 20 September 2018, 02:32:15 »
Actually that is not correct since you can update keyboard without being in “connected” state.
When in “connected” state, pressing a key on the keyboard does not highlight a button on JigOn UI?
Offline dorf
  • divine creator
« Reply #307 on: Thu, 20 September 2018, 02:46:16 »
Ok, didn't know that. I've always been connected. But when I am it does not highlight automatically. I have to manually click on it.
Offline OracleKev
« Reply #308 on: Thu, 20 September 2018, 07:26:48 »
Once you are in the connected state, can you put focus on another app like Notepad and confirm a key press enters pcb matrix sequence?  e.g. "Esc" should output '[a-a]'
This confirms the keyboard is in the connected state.
If the keyboard does not enter the connected state even if JigOn reports "Connected"
One of the followings could be a cause: 1) L3 board firmware is not up to date 2) L3 board is not directly connected to PC 3) there are multiple L3 boards connected.
Offline dorf
  • divine creator
« Reply #309 on: Thu, 20 September 2018, 13:35:25 »
So when I read this I could remember seeing the keyboard writing strange characters when connected before. I'm a swede so obviosly I use swedish keyboard. When connected I get "åc+b¨åc+c¨åc+d¨åc+e¨åc+f¨åc+g" when I write QWERTY. Switching over to english keyboard writing QWERTY i get "[c-b][c-c][c-d][c-e][c-f][c-g]" and automatic highlighting works! So lesson learned. Always use english keyboard when using JigOn.
Offline dorf
  • divine creator
« Reply #310 on: Thu, 20 September 2018, 15:20:28 »
I have two more questions that I think needs clarification.
First, it's been mentioned that it's possible to flash l3.hex in other ways. How?
Second, I've seen alot of posts saying that PCB gets borked when leds are soldered. What's up with that? I've not done it and don't feel the need for it but anyways...
Offline nug
« Reply #311 on: Thu, 20 September 2018, 16:27:00 »
As far as I know, there are two ways to flash the hex:
1) Via the bootloader, using L3_171209.zip from http://kbdlab.co.kr/index.php?document_srl=2702787&mid=board_sw OracleKev discussed this here: https://geekhack.org/index.php?topic=95066.msg2660521#msg2660521
2) Or using an ISP flasher with L3_bootloader.zip from the same kbdlab link above.
Offline MajorKoos
« Reply #312 on: Fri, 21 September 2018, 09:20:02 »
Built mine yesterday.
At first, even though the keyboard worked in windows the app would not connect or show me the keymap.
Changing ports on the hub didn't work as usual.
I redownloaded the app and it connected fine.
I left the firmware stock.
Offline Lansky
  • Realest motherthocker
« Reply #313 on: Sat, 22 September 2018, 11:44:15 »
Got mine in the mail yesterday. It looks great, no visible defects, scratches or dents. Thanks, LZ!  :)
Offline dorf
  • divine creator
« Reply #314 on: Sat, 22 September 2018, 11:48:52 »
Thanks, All for your help!
While I am still receiving that same communication error that I posted before, I switched to a new PC and was able to get the Jigon software to connect. So everything seems to be working now!
So when you updated the keymap connected with JigOn this solved the issue with the spacebar? Did you have to do anything else?
Offline hayt
« Reply #315 on: Tue, 25 September 2018, 20:34:39 »
Very happy!
Offline HPE1000
  • Keycap Paparazzo
« Reply #316 on: Tue, 25 September 2018, 23:07:33 »
Very happy!
Looks awesome!  :thumb:
Offline Lansky
« Reply #317 on: Wed, 26 September 2018, 04:06:20 »
Very happy!
That looks really good. Can't wait to assemble mine.  :)
Offline MajorKoos
« Reply #318 on: Wed, 26 September 2018, 08:10:10 »
It still surprises me how HEAVY it is.
I suspect it weighs more than the CLS.
Offline Lansky
« Reply #319 on: Thu, 27 September 2018, 04:54:17 »
I agree, every time I move it around I'm surprised by how heavy it is. When you look at it, it doesn't look THAT heavy. And I haven't even assembled mine yet.  :)
Offline Sshimosawa
Re: [GB] LZ GH V2 : [Completed]
« Reply #320 on: Thu, 27 September 2018, 13:05:59 »
the heft threw me, too. its a beast. 204434-0
Offline Etherealsound
« Reply #321 on: Thu, 27 September 2018, 13:31:56 »
the heft threw me, too. its a beast. (Attachment Link)
That's a really nice keyset. Where are those mods from?
Offline japanesehorrorwriter
« Reply #322 on: Thu, 27 September 2018, 13:55:46 »
Its a mix: GMK Led Zepp alphas, Samurai Mods, maroon esc from oco.
« Last Edit: Thu, 27 September 2018, 14:11:11 by japanesehorrorwriter »
« Reply #323 on: Thu, 27 September 2018, 16:06:17 »
Very happy!
What is that insanely cool desk pad you have here???
Offline wholypantalones
  • text and icon mods plz.
« Reply #324 on: Fri, 28 September 2018, 06:44:19 »
Very happy!
Was kinda wondering that myself.  :thumb:
Offline hayt
« Reply #325 on: Fri, 28 September 2018, 10:57:26 »
Very happy!
Kitty litter matt :)
Offline MajorKoos
« Reply #326 on: Fri, 28 September 2018, 11:10:52 »
bwah ha ha ha ha!
Bravo sir.  Bravo.
« Last Edit: Sat, 29 September 2018, 05:39:04 by MajorKoos »
Offline Sshimosawa
« Reply #327 on: Sat, 29 September 2018, 00:33:44 »
Fantastic.
Offline Helldrop
« Reply #328 on: Thu, 04 October 2018, 01:25:19 »
Ready to build my GH V2!
The top was re-anodized and the bottom was cerakote-coated.
Offline Lansky
« Reply #329 on: Thu, 04 October 2018, 03:53:09 »
Very cool with the cerakoting. Would love some more pictures of the bottom.  :)
What color did the case have before?
Offline Helldrop
« Reply #330 on: Thu, 04 October 2018, 04:43:18 »
Of course. After finishing building this keeb, I’ll post more pics.
It used to be grey.
Offline Lansky
« Reply #331 on: Thu, 04 October 2018, 05:24:45 »
It used to be grey.
Thanks, can't wait to see more of it.  :thumb:
Offline CommonCurt
  • One of the cool kids
  • 🍒 Beige or Bust
    • My Flickr Page
« Reply #332 on: Thu, 04 October 2018, 06:08:48 »
Wow!   That looks amazing.
Was the case color red originally?
« Last Edit: Thu, 04 October 2018, 09:05:54 by CommonCurt »
Some of Ye ole  Keyboards -->
WTB/WTS/WTT ---->
Offline Lansky
« Reply #333 on: Thu, 04 October 2018, 06:28:05 »
It used to be grey.
Offline CommonCurt
  • 🍒 Beige or Bust
    • My Flickr Page
« Reply #334 on: Thu, 04 October 2018, 06:32:35 »
It used to be grey.
Didn't see where you said it was originally grey.
WTB/WTS/WTT ---->
Offline radio_killah
  • Chinchillin'
« Reply #335 on: Sat, 06 October 2018, 21:03:12 »
Anyone looking to sell?
Offline LifeZ
  • LifeZone
« Reply #336 on: Sun, 07 October 2018, 03:16:08 »
 I have changed the color of the remaining quantity after GB finishing.
The color of the milky.
I will make order. About 5~7 unit.
Preorder ...
https://imgur.com/a/McJrXZJ
LZ Limited
Offline CommonCurt
  • 🍒 Beige or Bust
    • My Flickr Page
« Reply #337 on: Sun, 07 October 2018, 03:23:20 »
Preorder ...
That's awesome.
Is it powdercoated or cerikote?
WTB/WTS/WTT ---->
Offline LifeZ
  • LifeZone
« Reply #338 on: Sun, 07 October 2018, 03:29:23 »
Preorder ...
That's awesome.
It is powdercoated
LZ Limited
Offline MajorKoos
« Reply #339 on: Sun, 07 October 2018, 06:05:06 »
Preorder ...
Looks great :)
Offline LightningXI
  • PPD
    • ArtisanMacro
« Reply #340 on: Sun, 07 October 2018, 08:28:01 »
Preorder ...
Oh man. I might be interested. Same cost?
Sent from my mobile using Tapatalk
Offline Helldrop
« Reply #341 on: Sun, 07 October 2018, 09:47:14 »
Preorder ...
Amazing! It seems a little brighter than cerakoted one.
« Reply #342 on: Sun, 07 October 2018, 10:21:43 »
Offline LifeZ
  • LifeZone
Re: [GB] LZ GH V2 : [Completed] + Extra sale milky colors
« Reply #343 on: Mon, 08 October 2018, 02:19:48 »
Milky Color, Order here (Today, Korea time, PM 19:00)
all out
« Last Edit: Sun, 21 October 2018, 00:34:00 by LifeZ »
LZ Limited
Offline Lansky
« Reply #344 on: Mon, 08 October 2018, 14:32:29 »
I'm having problems programming my PCB. I get the "Connected" pop-up in the JigOn software but it registers no keypresses there. It works fine in Windows.
I'm not able to update or reset the firmware either, so I guess it's not actually connected. I've tried four different USB ports (half of them directly on the motherboard) and three different USB cables. No luck.
Any suggestions?  :)
Offline MajorKoos
« Reply #345 on: Mon, 08 October 2018, 15:39:31 »
Any suggestions?  :)
Couple of things to check:
Is your OS set to English US?
Is it the only keyboard that's plugged in?
Is your phone plugged in?
If you download a fresh copy of the JigOn software, launch it and hit connect does it download the keymap or does everything stay gray?
If you connect and then switch to notepad and start typing what output do you get?
Offline HPE1000
  • Keycap Paparazzo
« Reply #346 on: Mon, 08 October 2018, 15:44:27 »
If I didn't already have so many keyboards I would be all over those white ones. They look great :D
Offline Lansky
« Reply #347 on: Mon, 08 October 2018, 17:22:42 »
Any suggestions?  :)
My OS is set to English US, yes.
It's the only board that's plugged in, my phone is not plugged in.
The JigOn software looks like this after connecting: https://i.imgur.com/zFZdSYo.png
Typing in Notepad gives me this output:
"åd+c¨åd+d¨åd+e¨åd+c¨åd+d¨åd+e¨åd+f¨åd+h¨åd+g
So I guess that might be causing the issue. Not sure why it's showing up like that when my keyboard and OS is set to en-US.
EDIT: I just realized that I still had the Danish keyboard layout added in the language menu, apparently it wasn't enough to just switch to the en-US layout, I had to remove the Danish layout. Now it works!  ;D
« Last Edit: Mon, 08 October 2018, 17:27:30 by Lansky »
Offline MajorKoos
« Reply #348 on: Mon, 08 October 2018, 18:11:54 »
I didn't know that was required either.
Thanks for sharing.
Offline Lansky
« Reply #349 on: Tue, 09 October 2018, 03:47:38 »
Thanks for sharing.
No problem, glad I could provide some useful information.
Appreciate the help!
