Author Topic: Will this converter work for a Terminal Model M 1392595?  (Read 2041 times)
Offline KahunaKona
« on: Sun, 08 April 2018, 14:37:43 »
https://www.ebay.com/itm/Generic-USB-2-0-to-Rj-45-Ethernet-Adapter-Cables-Hubs-Adapters-Computer/202169319776?epid=15011027474&hash=item2f123b0160:g:sicAAOSwldRaSooY
Will a simple RJ45 to USB converter work for the keyboard that I have (RJ-45 Terminal Model M Keyboard) and will it be compatible with Windows 10? I do not want to physically convert the original wire, just pop a converter on there and call it done, so hopefully this is an okay one!
Offline ErgoMacros
Re: Will this converter work for a Terminal Model M 1392595?
« Reply #1 on: Sun, 08 April 2018, 15:00:38 »
Looks to me like the adapter you linked to let's you speak "Ethernet" out a USB port.
Won't work.
I think what you're looking for is one of these:
  https://geekhack.org/index.php?topic=72052.0;topicseen
Good luck!
Today's quote: '...“but then the customer successfully broke that.”
Offline Snowdog993
  • Grace Under Pressure
  • Justifiably Clueless.
« Reply #2 on: Mon, 09 April 2018, 18:06:08 »
Controller swap will work best.
https://geekhack.org/index.php?topic=61878.msg1721863#msg1721863
Edit:
If you feel you want to add the LED's in the future, you can. However, the keyboard will be just fine without them.
https://geekhack.org/index.php?topic=61878.msg1764458#msg1764458
Edit 2:
If you find it hard (impossible) to obtain the controller, you can do this:
https://geekhack.org/index.php?topic=10737.msg1723209#msg1723209
« Last Edit: Mon, 09 April 2018, 18:37:54 by Snowdog993 »
