Author Topic: [SOLD] Oddball PREH Commander POS board, $28.65 shipped  (Read 6766 times)
Offline ander
  • I type, therefore I am
« on: Mon, 09 April 2018, 18:53:55 »
Preh Commander MC128WX Keyboard
BIN for a mere $8.00 + $20.65 shipping
These are rated for 50M keypresses (see product info here), so unless the seller has a severely inflated opinion of RDs, they're apparently mechanical of some type.
I'm assuming it's dye-subbed, as pad printing wouldn't last long in a POS environment, right?
Also note the key labeled "DO NOT USE"—I'm tempted to buy the thing just to see what's under there.  :?)
« Last Edit: Tue, 01 May 2018, 03:35:01 by ander »
Re: Oddball PREH Commander POS board, $28.65 shipped
« Reply #1 on: Mon, 09 April 2018, 19:59:58 »
I would have bought it for the caps, even though I am not a Cherry user, but "Enter" is almost worn off, so it is surely not durable.
- D Trump 2026-10-24
Offline Blaise170
  • ALPS キーボード
    • XYZ
« Reply #2 on: Tue, 10 April 2018, 09:55:06 »
It's not mechanical. It uses a "polyester switching membrane". In fact, I don't think any PREH boards are mechanical.
Offline ander
« Reply #3 on: Wed, 11 April 2018, 00:49:14 »
You're right, Fo, I didn't spot that... Thanks!
I was just going by the "50 million keypresses" in the product literature. But I doubt anyone ever counts their keypresses... If they do, they really need to get out more.
