Author Topic: only number 9 and character '-‘ can be input correctly  (Read 3661 times)
Offline 243750496
« on: Thu, 12 April 2018, 00:43:04 »
config.h
Copyright 2012 Jun Wako <wakojun@gmail.com>
This program is free software: you can redistribute it and/or modify
it under the terms of the GNU General Public License as published by
the Free Software Foundation, either version 2 of the License, or
(at your option) any later version.
This program is distributed in the hope that it will be useful,
but WITHOUT ANY WARRANTY; without even the implied warranty of
MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
GNU General Public License for more details.
You should have received a copy of the GNU General Public License
along with this program.  If not, see <http://www.gnu.org/licenses/>;.
#ifndef CONFIG_H
#define CONFIG_H
/* USB Device descriptor parameter */
#define VENDOR_ID       0xFEED
#define PRODUCT_ID      0x1111
#define DEVICE_VER      0x0001
#define MANUFACTURER    CC
#define PRODUCT         Onekey
#define DESCRIPTION     CC keyboard firmware for GH60-CC
/* key matrix size */
#define MATRIX_ROWS 5
#define MATRIX_COLS 14
/* define if matrix has ghost */
//#define MATRIX_HAS_GHOST
/* Set 0 if debouncing isn't needed */
#define DEBOUNCE    5
/* Mechanical locking support. Use KC_LCAP, KC_LNUM or KC_LSCR instead in keymap */
#define LOCKING_SUPPORT_ENABLE
/* Locking resynchronize hack */
#define LOCKING_RESYNC_ENABLE
/* key combination for command */
#define IS_COMMAND() ( \
    keyboard_report->mods == (MOD_BIT(KC_LSHIFT) | MOD_BIT(KC_RSHIFT)) \
 * Feature disable options
 *  These options are also useful to firmware size reduction.
/* disable debug print */
//#define NO_DEBUG
/* disable print */
//#define NO_PRINT
/* disable action features */
//#define NO_ACTION_LAYER
//#define NO_ACTION_TAPPING
//#define NO_ACTION_ONESHOT
//#define NO_ACTION_MACRO
//#define NO_ACTION_FUNCTION
/* PS/2 mouse */
#ifdef PS2_USE_BUSYWAIT
#   define PS2_CLOCK_PORT  PORTD
#   define PS2_CLOCK_PIN   PIND
#   define PS2_CLOCK_DDR   DDRD
#   define PS2_CLOCK_BIT   1
#   define PS2_DATA_PORT   PORTD
#   define PS2_DATA_PIN    PIND
#   define PS2_DATA_DDR    DDRD
#   define PS2_DATA_BIT    2
#endif
/* PS/2 mouse interrupt version */
#ifdef PS2_USE_INT
/* uses INT1 for clock line(ATMega32U4) */
#define PS2_CLOCK_PORT  PORTD
#define PS2_CLOCK_PIN   PIND
#define PS2_CLOCK_DDR   DDRD
#define PS2_CLOCK_BIT   1
#define PS2_DATA_PORT   PORTD
#define PS2_DATA_PIN    PIND
#define PS2_DATA_DDR    DDRD
#define PS2_DATA_BIT    2
#define PS2_INT_INIT()  do {    \
    EICRA |= ((1<<ISC11) |      \
              (0<<ISC10));      \
} while (0)
#define PS2_INT_ON()  do {      \
    EIMSK |= (1<<INT1);         \
} while (0)
#define PS2_INT_OFF() do {      \
    EIMSK &= ~(1<<INT1);        \
} while (0)
#define PS2_INT_VECT    INT1_vect
#endif
/* PS/2 mouse USART version */
#ifdef PS2_USE_USART
#if defined(__AVR_ATmega16U4__) || defined(__AVR_ATmega32U4__)
/* XCK for clock line and RXD for data line */
#define PS2_CLOCK_BIT   5
/* synchronous, odd parity, 1-bit stop, 8-bit data, sample at falling edge */
/* set DDR of CLOCK as input to be slave */
#define PS2_USART_INIT() do {   \
    PS2_CLOCK_DDR &= ~(1<<PS2_CLOCK_BIT);   \
    PS2_DATA_DDR &= ~(1<<PS2_DATA_BIT);     \
    UCSR1C = ((1 << UMSEL10) |  \
              (3 << UPM10)   |  \
              (0 << USBS1)   |  \
              (3 << UCSZ10)  |  \
              (0 << UCPOL1));   \
    UCSR1A = 0;                 \
    UBRR1H = 0;                 \
    UBRR1L = 0;                 \
} while (0)
#define PS2_USART_RX_INT_ON() do {  \
    UCSR1B = ((1 << RXCIE1) |       \
              (1 << RXEN1));        \
} while (0)
#define PS2_USART_RX_POLL_ON() do { \
    UCSR1B = (1 << RXEN1);          \
} while (0)
#define PS2_USART_OFF() do {    \
    UCSR1C = 0;                 \
    UCSR1B &= ~((1 << RXEN1) |  \
                (1 << TXEN1));  \
} while (0)
#define PS2_USART_RX_READY      (UCSR1A & (1<<RXC1))
#define PS2_USART_RX_DATA       UDR1
#define PS2_USART_ERROR         (UCSR1A & ((1<<FE1) | (1<<DOR1) | (1<<UPE1)))
#define PS2_USART_RX_VECT       USART1_RX_vect
#endif
#endif
#endif
keymap_common_gh60_cc.h
#ifndef KEYMAP_COMMON_GH60_CC_H
#define KEYMAP_COMMON_GH60_CC_H
#include <stdint.h>
#include <stdbool.h>
#include "keycode.h"
#include "action.h"
#include "action_macro.h"
#include "report.h"
#include "host.h"
#include "print.h"
#include "debug.h"
#include "keymap.h"
#define KEYMAP( \
    K00, K01, K02, K03, K04, K05, K06, K07, K08, K09, K0A, K0B, K0C, K0D, \
    K10, K11, K12, K13, K14, K15, K16, K17, K18, K19, K1A, K1B, K1C, K1D, \
    K20, K21, K22, K23, K24, K25, K26, K27, K28, K29, K2A, K2B,      K2D, \
    K30,      K32, K33, K34, K35, K36, K37, K38, K39, K3A, K3B, K3C, K3D, \
    K40, K41, K42,           K45,                     K4A, K4B, K4C, K4D  \
    { KC_##K00, KC_##K01, KC_##K02, KC_##K03, KC_##K04, KC_##K05, KC_##K06, KC_##K07, KC_##K08, KC_##K09, KC_##K0A, KC_##K0B, KC_##K0C, KC_##K0D }, \
    { KC_##K10, KC_##K11, KC_##K12, KC_##K13, KC_##K14, KC_##K15, KC_##K16, KC_##K17, KC_##K18, KC_##K19, KC_##K1A, KC_##K1B, KC_##K1C, KC_##K1D }, \
    { KC_##K20, KC_##K21, KC_##K22, KC_##K23, KC_##K24, KC_##K25, KC_##K26, KC_##K27, KC_##K28, KC_##K29, KC_##K2A, KC_##K2B,    KC_NO, KC_##K2D }, \
    { KC_##K30,    KC_NO, KC_##K32, KC_##K33, KC_##K34, KC_##K35, KC_##K36, KC_##K37, KC_##K38, KC_##K39, KC_##K3A, KC_##K3B, KC_##K3C, KC_##K3D }, \
    { KC_##K40, KC_##K41, KC_##K42,    KC_NO,    KC_NO,    KC_##K45, KC_NO,    KC_NO,    KC_NO,    KC_NO, KC_##K4A, KC_##K4B, KC_##K4C, KC_##K4D }  \
#endif
keymap_gh60_cc.c
#include "keymap_common_gh60_cc.h"
 * CC
const uint8_t PROGMEM keymaps[][MATRIX_ROWS][MATRIX_COLS] = {
/* MIT Layout (default)
 * |ESC |  1  |  2  |  3  |  4  |  5  |  6  |  7  |  8  |  9  |  0  |  -  |  =  | Backsp |
 * |Tab  |  Q  |  W  |  E  |  R  |  T  |  Y  |  U  |  I  |  O  |  P  |  [  |  ]  |   \   |
 * |Caps  |  A  |  S  |  D  |  F  |  G  |  H  |  J  |  K  |  L  |  ;  |  '  |   Enter    |
 * |Shift   |  Z  |  X  |  C  |  V  |  B  |  N  |  M  |  ,  |  .  |  /  |  Shift   | Fn  |
 * | Ctrl|Super| Alt |                 Space                     | Left | Down| Up |Right|
    KEYMAP(
        ESC, 1,   2,   3,   4,   5,   6,   7,   8,   9,   0,   MINS,EQL, BSPC, \
        TAB, Q,   W,   E,   R,   T,   Y,   U,   I,   O,   P,   LBRC,RBRC,BSLS, \
        LCTL,A,   S,   D,   F,   G,   H,   J,   K,   L,   SCLN, QUOT,     ENT, \
        LSFT,Z,   X,   C,   V,   B,   N,   M,   COMM,DOT, SLSH, RSFT,     FN0, \
        LCTL,LGUI,LALT,          SPC,                      LEFT,DOWN,UP,RGHT),
/* MIT Layout (Fn)
 * | ESC | F1  | F2  |  F3 |  F4 |  F5 |  F6 |  F7 |  F8 |  F9 | F10 | F11 | F12| prtscn |
 * | Ctrl|     | Alt |                                            | HOME| END |Insrt|Delt|
    KEYMAP(
        ESC, F1,  F2,  F3,  F4,  F5,  F6,  F7,  F8,  F9,  F10, F11, F12, PSCR, \
        TRNS,TRNS,TRNS,TRNS,TRNS,TRNS,TRNS,TRNS,TRNS,TRNS,TRNS,TRNS,TRNS,TRNS, \
        TRNS,TRNS,TRNS,TRNS,TRNS,TRNS,TRNS,TRNS,TRNS,TRNS,TRNS,TRNS,     TRNS, \
        TRNS,  NO,TRNS,          TRNS,               HOME, END, INS,DELETE),
const action_t PROGMEM fn_actions[] = {
  • = ACTION_LAYER_MOMENTARY(0),
  • [1] = ACTION_LAYER_MOMENTARY(1),
    matrix_gh60_cc.c
    Copyright 2017 Jun Wako <wakojun@gmail.com>
    along with this program. If not, see <" target="_blank">
* scan matrix
#include <stdint.h>
#include <avr/io.h>
#include "debug.h"
#include "timer.h"
#include "matrix.h"
#ifndef DEBOUNCE
# define DEBOUNCE 5
#endif
/* matrix state(1:on, 0:off) */
static matrix_row_t row_debounced = 0;
static matrix_row_t row_debouncing = 0;
static bool debouncing = false;
static uint16_t debouncing_time = 0;
static uint8_t debouncing = DEBOUNCE;
static matrix_row_t matrix[MATRIX_ROWS];
static matrix_row_t matrix_debouncing[MATRIX_ROWS];
static matrix_row_t read_cols(void);
static void init_cols(void);
static void unselect_rows(void);
static void select_row(uint8_t row);
void matrix_init(void)
debug_enable = true;
debug_matrix = true;
debug_mouse = true;
// PB0: Input with pull-up(DDR:0, PORT:1)
DDRB &= ~(1<<0);
PORTB |= (1<<0);
// initialize row and col
unselect_rows();
init_cols();
// initialize matrix state: all keys off
for (uint8_t i=0; i < MATRIX_ROWS; i++) {
matrix = 0;
matrix_debouncing = 0;
uint8_t matrix_scan(void)
matrix_row_t r = (PINB&(1<<0) ? 0 : 1);
if (row_debouncing != r) {
row_debouncing = r;
debouncing = true;
debouncing_time = timer_read();
if (debouncing && timer_elapsed(debouncing_time) > DEBOUNCE) {
row_debounced = row_debouncing;
debouncing = false;
return 1;
for (uint8_t i = 0; i < MATRIX_ROWS; i++) {
select_row(i);
_delay_us(30); // without this wait read unstable value.
matrix_row_t cols = read_cols();
if (matrix_debouncing != cols) {
matrix_debouncing = cols;
if (debouncing) {
debug("bounce!: "); debug_hex(debouncing); debug("\n");
unselect_rows();
if (debouncing) {
if (--debouncing) {
_delay_ms(1);
} else {
matrix = matrix_debouncing;
return 1;
inline
matrix_row_t matrix_get_row(uint8_t row)
return row_debounced;
return matrix[row];
Col: 1 2 3 4 5 6 7 8 9 10 11 12 13 14
Pin: D0 D1 D2 D3 D4 D5 D6 D7 C0 C1 C2 C3 C4 C5
// Input with pull-up(DDR:0, PORT:1)
DDRD &= ~(1<<7 | 1<<6 | 1<<5 | 1<<4 | 1<<3 | 1<<2 | 1<<1 | 1<<0);
PORTD |= (1<<7 | 1<<6 | 1<<5 | 1<<4 | 1<<3 | 1<<2 | 1<<1 | 1<<0);
DDRC &= ~(1<<5 | 1<<4 | 1<<3 | 1<<2 | 1<<1 | 1<<0);值为00000000&11000000=00000000
PORTC |= (1<<5 | 1<<4 | 1<<3 | 1<<2 | 1<<1 | 1<<0);值为00000000|00111111=00111111
return (PIND&(1<<0) ? 0 : (1<<0)) |
(PIND&(1<<1) ? 0 : (1<<1)) |
(PIND&(1<<2) ? 0 : (1<<2)) |
(PIND&(1<<3) ? 0 : (1<<3)) |
(PIND&(1<<4) ? 0 : (1<<4)) |
(PIND&(1<<5) ? 0 : (1<<5)) |
(PIND&(1<<6) ? 0 : (1<<6)) |
(PIND&(1<<7) ? 0 : (1<<7)) |
(PINC&(1<<0) ? 0 : (1<<8)) |
(PINC&(1<<1) ? 0 : (1<<9)) |
(PINC&(1<<2) ? 0 : (1<<10)) |
(PINC&(1<<3) ? 0 : (1<<11)) |
(PINC&(1<<4) ? 0 : (1<<12)) |
(PINC&(1<<5) ? 0 : (1<<13));
Row: 1 2 3 4 5
Pin: C6 C7 A7 A6 A5
// Hi-Z(DDR:0, PORT:0) to unselect
DDRC &= ~0b11000000;//初始化后的值(执行过一遍init cols后)等于01000000&00111111=00000000:case0;等于10000000&00111111=00000000:case1,初始值为:00000000&00111111=00000000
PORTC &= ~0b11000000;//初始化后的值(执行过一遍init cols后)等于00111111&00111111=00111111:case0;等于00111111&00111111=00111111:case1,初始值为:00000000&00111111=00000000
DDRA &= ~0b11100000;//初始化后的值(执行过一遍init cols后)等于10000000&00011111=00000000:case2;等于01000000&00011111=00000000:case3;等于00100000&00011111=00000000:case4,初始值为:00000000&00011111=00000000
PORTA &= ~0b11100000;//初始化后的值(执行过一遍init cols后)等于00000000&00011111=00000000:case2;等于00000000&00011111=00000000:case3;等于00000000&00011111=00000000:case4,初始值为:00000000&00011111=00000000
// Output low(DDR:1, PORT:0) to select
switch (row) {
case 0:
DDRC |= (1<<6);//等于00000000|01000000=01000000:case0;
PORTC &= ~(1<<6);//等于00111111&10111111=00111111:case0;
break;
case 1:
DDRC |= (1<<7);//等于00000000|10000000=10000000:case1;
PORTC &= ~(1<<7);//等于00111111&01111111=00111111:case1;
break;
case 2:
DDRA |= (1<<7);//等于00000000|10000000=10000000
PORTA &= ~(1<<7);//等于00000000|01111111=00000000
break;
case 3:
DDRA |= (1<<6);//等于00000000|01000000=01000000
PORTA &= ~(1<<6);//等于00000000|10111111=00000000
break;
case 4:
DDRA |= (1<<5);//等于00000000|00100000=00100000
PORTA &= ~(1<<5);//等于00000000|11011111=00000000
break;
由于单片机芯片每次只能扫描一种状态(每大端口(C端口或C组端口):比如C,而不是C0~7中的小端口如:C1端口),切换状态需要使用Hiz(又称三态Or高阻态),如果不用高阻态重置状态就会出现处理器无法理解到底是新的(行:row的)高电平还是旧的(列:col的)高电平没变
matrix_gh60_cc.c
along with this program.  If not, see <" target="_blank">http://www.gnu.org/licenses/>;.
 * scan matrix
#include <stdint.h>
#include <avr/io.h>
#include <util/delay.h>
#include "print.h"
#include "debug.h"
#include "util.h"
#include "matrix.h"
#ifndef DEBOUNCE
#   define DEBOUNCE 5
#endif
    debug_mouse = true;
    DDRB  &= ~(1<<0);
    PORTB |=  (1<<0);
    unselect_rows();
    init_cols();
        matrix = 0;
        row_debouncing = r;
        debouncing = true;
        debouncing = false;
    return 1;
        select_row(i);
            if (debouncing) {
        unselect_rows();
    if (debouncing) {
        if (--debouncing) {
            _delay_ms(1);
        } else {
    return 1;
inline
    return matrix[row];
Row: 1  2  3  4  5
Pin: C6 C7 A7 A6 A5
    switch (row) {
        case 0:
            DDRC  |= (1<<6);
            PORTC &= ~(1<<6);
            break;
        case 1:
            DDRC  |= (1<<7);
            PORTC &= ~(1<<7);
            break;
        case 2:
            DDRA  |= (1<<7);
            PORTA &= ~(1<<7);
            break;
        case 3:
            DDRA  |= (1<<6);
            PORTA &= ~(1<<6);
            break;
        case 4:
            DDRA  |= (1<<5);
            PORTA &= ~(1<<5);
            break;
Makefile
# On command line:
# make all = Make software.
# make clean = Clean out built project files.
# make coff = Convert ELF to AVR COFF.
# make extcoff = Convert ELF to AVR Extended COFF.
# make program = Download the hex file to the device.
#                Please customize your programmer settings(PROGRAM_CMD)
# make teensy = Download the hex file to the device, using teensy_loader_cli.
#               (must have teensy_loader_cli installed).
# make dfu = Download the hex file to the device, using dfu-programmer (must
#            have dfu-programmer installed).
# make flip = Download the hex file to the device, using Atmel FLIP (must
#             have Atmel FLIP installed).
# make dfu-ee = Download the eeprom file to the device, using dfu-programmer
#               (must have dfu-programmer installed).
# make flip-ee = Download the eeprom file to the device, using Atmel FLIP
#                (must have Atmel FLIP installed).
# make debug = Start either simulavr or avarice as specified for debugging,
#              with avr-gdb or avr-insight as the front end for debugging.
# make filename.s = Just compile filename.c into the assembler code only.
# make filename.i = Create a preprocessed source file for use in submitting
#                   bug reports to the GCC project.
# To rebuild project do "make clean" then "make all".
# Target file name (without extension).
TARGET = gh60_cc
# Directory common source filess exist
TMK_DIR = ../../tmk_core
# Directory keyboard dependent files exist
TARGET_DIR = .
# project specific files
SRC = keymap_gh60_cc.c \
 matrix_gh60_cc.c \
 led_gh60_cc.c
CONFIG_H = config.h
# MCU name
#MCU = at90usb1287
#MCU = atmega32u4
MCU = at90usb1286
# Processor frequency.
#     This will define a symbol, F_CPU, in all source code files equal to the
#     processor frequency in Hz. You can then use this symbol in your source code to
#     calculate timings. Do NOT tack on a 'UL' at the end, this will be done
#     automatically to create a 32-bit value in your source code.
#     This will be an integer division of F_USB below, as it is sourced by
#     F_USB after it has run through any CPU prescalers. Note that this value
#     does not *change* the processor frequency - it should merely be updated to
#     reflect the processor speed set externally so that the code can use accurate
#     software delays.
F_CPU = 16000000
# LUFA specific
# Target architecture (see library "Board Types" documentation).
ARCH = AVR8
# Input clock frequency.
#     This will define a symbol, F_USB, in all source code files equal to the
#     input clock frequency (before any prescaling is performed) in Hz. This value may
#     differ from F_CPU if prescaling is used on the latter, and is required as the
#     raw input clock is fed directly to the PLL sections of the AVR for high speed
#     clock generation for the USB and other AVR subsections. Do NOT tack on a 'UL'
#     at the end, this will be done automatically to create a 32-bit value in your
#     source code.
#     If no clock division is performed on the input clock inside the AVR (via the
#     CPU clock adjust registers or the clock division fuses), this will be equal to F_CPU.
F_USB = $(F_CPU)
# Interrupt driven control endpoint task(+60)
OPT_DEFS += -DINTERRUPT_CONTROL_ENDPOINT
# Boot Section Size in *bytes*
#   Teensy halfKay   512
#   Teensy++ halfKay 1024
#   Atmel DFU loader 4096
#   LUFA bootloader  4096
#   USBaspLoader     2048
OPT_DEFS += -DBOOTLOADER_SIZE=8192
# Build Options
#   comment out to disable the options.
#BOOTMAGIC_ENABLE = yes # Virtual DIP switch configuration(+1000)
#MOUSEKEY_ENABLE = yes # Mouse keys(+4700)
#EXTRAKEY_ENABLE = yes # Audio control and System control(+450)
CONSOLE_ENABLE = yes # Console for debug(+400)
#COMMAND_ENABLE = yes    # Commands for debug and configuration
SLEEP_LED_ENABLE = yes  # Breathing sleep LED during USB suspend
#NKRO_ENABLE = yes # USB Nkey Rollover
#PS2_MOUSE_ENABLE = yes  # PS/2 mouse(TrackPoint) support
#PS2_USE_BUSYWAIT = yes # uses primitive reference code
#PS2_USE_INT = yes      # uses external interrupt for falling edge of PS/2 clock pin
#PS2_USE_USART = yes     # uses hardware USART engine for PS/2 signal receive(recomened)
# Search Path
VPATH += $(TARGET_DIR)
VPATH += $(TMK_DIR)
include $(TMK_DIR)/common.mk
include $(TMK_DIR)/protocol.mk
include $(TMK_DIR)/protocol/lufa.mk
include $(TMK_DIR)/rules.mk
led_gh60_cc.c
#include <avr/io.h>
#include "stdint.h"
#include "led.h"
LED Col 1:PB0
LED Col 2:PB1
LED Col 3:PB2
LED Col 4:PB3
LED Col 5:PB4
LED Col 6:PB5
LED Col 7:PB6
LED Col 8:PB7
LED Col 9:PF0
LED Col 10:PF1
LED Col 11:PF2
LED Col 12:PF3
LED Col 13:PF4
LED Col 14:PF5
LED Row 1:PA1
LED Row 2:PA2
LED Row 3:PA3
void led_set(uint8_t usb_led)
/*    if (usb_led & (1<<USB_LED_CAPS_LOCK)) {
        // output low
        DDRB |= (1<<2);
        PORTB &= ~(1<<2);
    } else {
        // Hi-Z
        DDRB &= ~(1<<2);
        PORTB &= ~(1<<2);
BTW:my web browser have some issue , so that can't format the text to code,sorry to show you code in this way
« Last Edit: Fri, 13 April 2018, 08:44:17 by 243750496 »
Offline 243750496
Re: only number 9 and character '-‘ can be input correctly
« Reply #1 on: Thu, 12 April 2018, 00:46:23 »
here's the keyboard image
« Last Edit: Thu, 12 April 2018, 01:33:46 by 243750496 »
