Author Topic: Handwire Diary: Southpaw Ergo Compact 1800 HHKB Layout  (Read 4550 times)
Offline iHateKnives
    • Old photography site
« on: Sat, 14 April 2018, 23:21:29 »
April 15, 2018
CAD file draft #1
Notes: I want to make the left and right sides as thin as the bezel under the arrow cluster. I also want to make the middle and lower layers bigger!
SA Camping layout
Notes: I made this entire layout to fit SA Camping. The spacebars are 2.25u. I'll put the R3 Mountain novelty keys on them
POK3R 67g Zealios + XDA Canvas + SA Camping
Offline BobCarltheThird
Re: Handwire Diary: Southpaw Ergo Compact 1800 HHKB Layout
« Reply #1 on: Sat, 14 April 2018, 23:57:46 »
So its similar to a LZ ergo with a numpad on the left? What are you making the plate out of?
***loads of Vaseline for my meme TMO50 -- Acereconkeys
Offline iHateKnives
« Reply #2 on: Sun, 15 April 2018, 01:15:54 »
It's more of a mad love child between Duck Jet Fire and LZ ErGO with a Southpaw HHKB mutation, buhahaha. Making the plate out of Aluminum but hopefully I can go for Brass if the budget allows for it. I'm trying to keep everything (case, plate, wiring, controller, switches, hydrodipping, and stabs) under $310. So far, my rough canvassing is under budget by $20!
« Last Edit: Sun, 15 April 2018, 01:25:20 by iHateKnives »
Offline iHateKnives
« Reply #3 on: Thu, 28 June 2018, 01:55:27 »
Updated the layout drastically to let me design a better looking case. Thinking of getting some bits from the Model F! Case design to follow real soon. My semester just finished so I can get back to this  :D
