Author Topic: Help identify this LED  (Read 2951 times)
Offline emenelopee
  • *klomp klomp klomp* I step on your house 🦖
« on: Mon, 16 April 2018, 23:03:39 »
I have a DZ60 REV 2.0 60% pcb from https://kbdfans.cn/collections/pcb/products/dz60-60-pcb and was hoping to replace the underlights with different LEDs. Can anyone help me identify these smd LEDs and suggest a UV replacement that would work? I have no idea about the spec other than they're approx. 5mm x 5mm, 4-pin rgb. I have seen 6-pin, and two pin: the latter makes sense for a mono-colour but connectors are too big and don't mesh with the 4-pin pads; the latter is just weird as why would a mono-colour need 6 pins (also they wouldn't mesh with the 4-pin)?
Offline TalkingTree
    • My projects
Re: Help identify this LED
« Reply #1 on: Tue, 17 April 2018, 05:16:45 »
QMK natively supports two kind of RGB LEDs: WS2811 (and its variants) and the SK6812. Since the latter is the only four pins one, I'm inclined to believe it is your LED.
Offline emenelopee
« Reply #2 on: Tue, 17 April 2018, 14:50:47 »
Nice detective work. Looks like it's only in RGB flavours, no single colour < 400 nm.
Offline jcoffin1981
« Reply #3 on: Tue, 24 April 2018, 00:54:29 »
Holy crap!  I just posted a few days ago in somebody's thread what a brilliant idea a numberpad on the left side would be.  I can see in the OP's signature it actually exists.
