Author Topic: 2u GMK left shift  (Read 4988 times)
Offline LevelSteam
2u GMK left shift
« on: Sat, 21 April 2018, 17:22:57 »
So I hit a bit of a snag on my newest project. I was planning on throwing a 2u left shift on the board, but forgot that GMK Oblivion didn't come with one. I have the spacebar kit which has a blank 2u cap that will fit, but it's convex on top so it sort of doesn't fit the profile as much as I'd like it to.
I've searched a lot but can't really find anything better to put there. Does anyone know of any novelties or places to buy 2u blanks in cherry profile?
Re: 2u GMK left shift
« Reply #1 on: Sat, 21 April 2018, 17:34:14 »
The only 2u you'll find in Cherry profile will be r1 for backspace
If you want r4 your options are 2.25u and 1.75u
Offline Poesjuh
« Reply #2 on: Sat, 21 April 2018, 17:35:22 »
Afaik the only set that has one right now is 9009 R2.
Offline LevelSteam
« Reply #3 on: Sat, 21 April 2018, 17:48:12 »
Hmm, sounds like my spacebar will be my best bet then. Any 2u artisans/customs available or coming up?
Offline Poesjuh
« Reply #4 on: Sat, 21 April 2018, 18:08:41 »
GMK Violet Tendencies will have a 2u shift btw.
Offline LevelSteam
« Reply #5 on: Sat, 21 April 2018, 18:48:28 »
Oh yeah, forgot about that set. It's running after GMK Phantom isn't it? Edit: Just rechecked the page here, sooner than that even! Nice!
I'll just use my 2u spacebar until that rolls around.
« Last Edit: Sat, 21 April 2018, 18:51:31 by LevelSteam »
