Author Topic: KBD75 - LALT registering as LGUI. Activating Windows key instead of alt.  (Read 1961 times)
Offline Yaoihaandz
Not entirely sure why it’s doing this and I’ve tried flashing it several times (maybe I’m doing it wrong or with an old version of QMK flasher) but it has not set my keys back. Switches are soldered in the right slots as well. If anyone’s got any idea what could be the problem please let me know. Also I’m new here so hello all :D
Offline xondat
  • i'm not a star
Maybe post the keymap? :thumb:
Also, welcome!
If it had been a non-DIY keyboard I would have guessed that you had put it in Macintosh mode, where the position of the Alt/Option and Win/Command keys are swapped. But that should happen on both sides of the keyboard, not just the left.
Do check again which keymap you have installed ... and also the order of your keycaps. ;)
