Author Topic: Does this kind of keyboard exist? RGB, ISO layout, White case, etc...  (Read 2385 times)
Offline truie
Hi. Apologies if this is the wrong place to ask this but I'm ready to move on from my k70 rbg and try something new but there's a very particular kind of keyboard I'd like to swap to.  I'm thinking it might be too specific to find.   :(
Ideally I would like to have a full size keyboard with white case/ White PBT keycaps in ISO layout with cherry blues and RGB backlighting.  Are there any boards out there that cover all those things right now? Or a website where I could custom order something like that? And if that's not possible what's the closest I could come to this "dream" keyboard I have in mind?  I think the inclusion of RGB lightning is probably the killer here to finding a perfect match but  I appreciate anyone that has any answers for this. Thank you
Re: Does this kind of keyboard exist? RGB, ISO layout, White case, etc...
« Reply #1 on: Sun, 29 April 2018, 21:06:00 »
https://mechanicalkeyboards.com/shop/index.php?l=product_detail&p=3479 this is ANSI RGB with a white case, i think there's an ISO version but i'm not sure where it's sold
Offline truie
« Reply #2 on: Sun, 29 April 2018, 22:04:12 »
That is actually the one I'm planning to purchase if there's none that matched all those preferences I had ha  :))  If it had the ISO layout it would be perfect but I may just have to suck it up and deal with the typical ANSI. Thanks for looking for me!
« Reply #3 on: Sun, 29 April 2018, 23:27:16 »
ANSI is good because it has more options in terms of aftermarket keycaps
Offline rich1051414
« Reply #4 on: Mon, 30 April 2018, 02:43:57 »
It's not hard to find keycaps in ISO, but ansi is the standard, and everything has that option first. Good luck though if you are expecting good regional iso layout options for custom keyboards though. That stuff is usually even less than an after thought when sets are put together xD
