Author Topic: Replacement centered off-center caps lock?  (Read 12304 times)
Offline Blaise170
  • ALPS キーボード
    • XYZ
« on: Tue, 01 May 2018, 12:03:44 »
I have a weird keyboard with a centered but also off center caps lock. I have two pictures of it (the black one) below. The white key on top is a Tai-Hao off-centered caps lock which does not fit (hangs to the right) and the white key on bottom is a standard centered caps lock. Anyone know where to find a replacement for the black one?
Offline Tactile
REΛLFORCE
Re: Replacement centered off-center caps lock?
« Reply #2 on: Tue, 01 May 2018, 13:26:04 »
No, to have it centred within a 1×1.5u rectangle is unusual. Which keyboard is that?
The only other keyboard I have heard or seen of it on are the Cherry "MX Board 2.0" and "3.0" but those have a very special profile.
BTW. Leopold has a Caps Lock that looks like that (1.5u) but actually has a centred stem.
« Last Edit: Tue, 01 May 2018, 13:27:50 by Findecanor »
Offline Blaise170
  • ALPS キーボード
    • XYZ
« Reply #3 on: Tue, 01 May 2018, 14:01:16 »
This particular key is from a Thermaltake Poseidon ZX, but I've also seen it on a couple of others like the Rapoo V500. The ZX is one of those boards with weird stabilizers that left shift, caps lock, and enter won't fit. I fixed the enter/shift problem by just removing the stabs since they aren't even necessary. Only key I have left to get working is caps lock but it looks like it might be even harder to find than I thought.
Offline curtisfong
« Reply #4 on: Sun, 19 June 2022, 18:00:37 »
Cherry 3800 / 3850s are slightly off center (3000 / 3494 very off center to the left).
I have an extra, if you still need.
