Author Topic: Fixing model M with missing stabiliser wire and broken stabiliser mount  (Read 1281 times)
Offline ag36
I recently acquired a blue label 1987 UK Model M with missing stabiliser wire and broken stabiliser mount, here's the result.
194937-0
194939-1
194941-2
194943-3
You'll need super glue, 1.2mm metal wire(I used copper). Spacebar uses 1.9mm.
I recommend buying a new stabiliser insert and keycap from Unicomp if you live in the US, also keycap to fit stabiliser wire is incompatible with the type used for stabiliser insert.
Model M*5, SSK*4, M13 black*1, Model F XT*1, AT*1 F107*1, Unicomp*1, 3278 *1, Leopold FC750R*2, 980M*2 FC980C*1 Filco majestouch 2 TKL*1, Cooler Master MasterKeys S PBT*1, Uniqey Q100*2, Ducky pocket*1, KBD75*2, KBD19X*2, HHKB pro 2*1, Type-S*1 Topre Realforce RGB*1, 108 all 30g*1, numpad*1, 87U*1 Dell AT101W*2, Alps64*2, V80 matias quiet click*2, Quiet liner *1, WYSE ASCII *1
