Author Topic: [GB] ALF X3 Renova GB ENDED  (Read 33447 times)
Offline zF_ScrambledEggz
    • zFrontier
« on: Fri, 04 May 2018, 12:11:42 »
ALF X3 Renova
GB starts begins on May 4th 9 pm PDT
https://en.zfrontier.com/products/alf-x3-renova
40 units ONLY, FCFS
Pricing:
478USD shipping included, DHL
+48USD if you want to upgrade your bottom alu insert to brass.
Timeframe:
Ends when all units were sold or on May 14
Estimated shipping: Sep or Oct 2018
Retro + Innovation
Features:
Classic hefty design
Mid-piece design
Side accent brass pieces
Front RGB strip
Bluetooth powered by MDBT40 (*lithium battery not included due to shipping reasons)
Mini USB
PCB powered by ydkb.io
Kmini layout
Top Housing:
3 RGB Lamps or Renova Logo engrave
Colors:
Housing and plate will have the same color: White, Silver, Gray, or Black
Aluminum Insert and mid-piece will have the same color: Purple, Green, Red, or Orange
195033-0195035-1195037-2195039-3195041-4
« Last Edit: Wed, 09 May 2018, 00:41:19 by zF_ScrambledEggz »
Offline Photoelectric
Re: [GB] ALF X3 Renova 40 units FCFS
« Reply #1 on: Fri, 04 May 2018, 20:04:52 »
Approval bump!
(Also, I love this design.)
Offline fcoury
« Reply #2 on: Fri, 04 May 2018, 20:10:25 »
Beautiful board. Is the PCB QMK compatible?
Offline JubJubCity
« Reply #3 on: Fri, 04 May 2018, 20:31:14 »
Love the board definitely joining
    • zFrontier
« Reply #4 on: Fri, 04 May 2018, 20:46:06 »
I believe the hardware does support QMK, you can flash QMK into the PCB. But itself its using the same thing as YD60BLE and COD67
Offline Windeh
  • a no name
« Reply #5 on: Fri, 04 May 2018, 22:09:14 »
Can we purchase additional mid piece & PCB? Would like a set for backup for such a large investment.
Offline Sshimosawa
« Reply #6 on: Fri, 04 May 2018, 23:03:46 »
Is it going live now? The page is still a 404.
Offline Starius
« Reply #7 on: Fri, 04 May 2018, 23:05:09 »
Yeah I don't see it yet either.
A email was sent out 15 minutes ago with a link, but that page is 404 currently.
Offline M
« Reply #8 on: Fri, 04 May 2018, 23:10:10 »
up
Offline natbuns
« Reply #9 on: Fri, 04 May 2018, 23:13:47 »
holy crackers I got in OwO.I was so worried I wouldn't make it into the groupbuy. I'm super excited I can't wait!
Offline Starius
« Reply #10 on: Fri, 04 May 2018, 23:15:24 »
I went with Black case, Orange insert.
How about you guys?
Offline Sshimosawa
« Reply #11 on: Fri, 04 May 2018, 23:17:22 »
Yep! Its up! Silver/ Orange + Brass for me.
Offline jlee755
« Reply #12 on: Fri, 04 May 2018, 23:17:58 »
wow, first limited GB, what a rush!!
I got white, green insert, 3 lights
Offline Starston3
« Reply #13 on: Fri, 04 May 2018, 23:18:44 »
I got white / purple with brass
Offline natbuns
« Reply #14 on: Fri, 04 May 2018, 23:20:40 »
I got White/Red with brass. I think SA by the Sea or Yuri sets would look good on it! :thumb:
« Last Edit: Fri, 04 May 2018, 23:24:57 by natbuns »
Offline ptiede
« Reply #15 on: Fri, 04 May 2018, 23:25:24 »
Went purple and white without the brass extra, probably gonna pair with violet tendencies
Offline Peppermint216
« Reply #16 on: Sat, 05 May 2018, 04:20:31 »
What kind of battery will we need?
Front RGB strip
Assuming this lights up?
Offline papa
« Reply #17 on: Sat, 05 May 2018, 12:38:29 »
they are not providing qmk firmware. the pcb author steals tmk codes, which is licensed with GPLv2, and won't share the codes.
The PCB can only be programmed with a stuipid website. If they stop running the website, you have no way to program the pcb.
Offline ptiede
« Reply #18 on: Sat, 05 May 2018, 12:45:02 »
I'm like 99% certain that it can run qmk. Someone just needs to port it. MechMerlin already said he was going to do that.
Offline papa
« Reply #19 on: Sat, 05 May 2018, 13:11:26 »
in theory it can, as long as some one port the codes.
I just wonder how well it will work with a thrid party firmware.
and it's sad they are not providing the codes while they should
Offline AuthenticDanger
« Reply #20 on: Sat, 05 May 2018, 18:28:31 »
Once I have mine, I'll probably take a crack at reverse engineering/porting to QMK
F Keys belong on the left.
Offline KeLorean
« Reply #21 on: Sat, 05 May 2018, 19:56:54 »
that would be amazing! im a qmk guy myself. i'd prefer if all my boards had a folder on the repro with a kelorean layout:)
on another note, does anybody know what up with that litium battery? do we need to find one from somewhere else???
Click it OR Ticket!
Offline M
« Reply #22 on: Sat, 05 May 2018, 20:26:36 »
does anybody know what up with that lithium battery? do we need to find one from somewhere else???
I would assume so, one isn't included with the board
    • zFrontier
« Reply #23 on: Sat, 05 May 2018, 20:39:34 »
Lithium Specs will be confirmed next monday ;)
also, the GB is going strong and we are left with less than 10 spots open! Be sure to join cause this will end very soon!
Offline Starius
« Reply #24 on: Sat, 05 May 2018, 22:00:24 »
This will be the most expensive keyboard I've bought so far, which is why I find it amusing it is a kit and not "working out of the box." ;)
To that end, this will be my first keyboard that requires me to solder the switches.   (I've been going in for keyboards with hotswap sockets as of late, such as the Kira, Tokyo60, and hopefully the new MiniVan drop.)
Not having soldered my own key switches before, I'm a bit nervous about doing it for the first time.  And I'm certainly not going to jump in and do it on my Renova until I'm good and ready.  I'm thinking I might want to hone my skills on practice PCBs first.  At any rate, will replacement PCBs for the Renova be available?  You know, in case I screw mine up (heaven forbid.) ;)
Offline kmba
  • Formerly tameone
« Reply #25 on: Sat, 05 May 2018, 22:03:12 »
You can buy soldering practice kits off Amazon. Or buy the cheapest keyboard pcb you can find and sacrifice some cheap switches for practice. Honestly, just watch several videos, get yourself a decent adjustable iron, some kester 60/40 or 63/37 0.31 solder and you'll be fine. It's pretty simple.
keyboards.
Offline Starius
« Reply #26 on: Sat, 05 May 2018, 22:06:23 »
Thanks for the advice, kmba.   I'll look into those!
Offline Harms
« Reply #27 on: Sun, 06 May 2018, 18:51:31 »
Is the spacebar 6.25u? It looks like it does not support a 6.25u spacebar.
Offline xondat
  • i'm not a star
« Reply #28 on: Sun, 06 May 2018, 19:07:18 »
Plate only supports 1.5 1 1.5 7 1.5
Offline Harms
« Reply #29 on: Sun, 06 May 2018, 19:08:29 »
Thank you! :)
Offline DePulse
« Reply #30 on: Sun, 06 May 2018, 20:19:01 »
Opting to join this GB but still waiting on my COD67 from zfront. How about updates on your past gb's? COD67? Month of May shipping still happening? Makes me want to join this GB sooner if the COD is arriving this month.
Offline vewy_nice
« Reply #31 on: Mon, 07 May 2018, 07:11:01 »
"This is a really nice looking board... But it's really expensive and I don't really need any more keyboards."
*LIMITED TO 40 UNITS*
"Oh this is much more reasonable now. I'm in for 1"
My brain is so dumb sometimes.
But white/purp going to look hot with this key combo
https://i.imgur.com/VUnyIog.jpg
Would it be possible to order an extra middle bit? I kinda also want a green... It's so hard to decide these things when there aren't any real "neutral" colors avalible...
« Last Edit: Mon, 07 May 2018, 07:34:40 by vewy_nice »
Offline lecorsair
« Reply #32 on: Mon, 07 May 2018, 09:59:19 »
By "middle bit", do you mean pcb and plate?
edit: nm, realized you meant the insert. actually that's a very good idea for a board like this - for whatever the mood/set calls for. Brilliant!
« Last Edit: Mon, 07 May 2018, 10:02:22 by lecorsair »
« Reply #33 on: Mon, 07 May 2018, 10:48:31 »
I'd be fine with this, but it'd have to be insert + plate.
Offline KeLorean
« Reply #34 on: Mon, 07 May 2018, 11:41:36 »
i agree! the option to switch inserts would be dope
Click it OR Ticket!
Offline vewy_nice
« Reply #35 on: Mon, 07 May 2018, 12:32:47 »
That's what I did with the MARS 8.0.
I spoke with the designer, and he sold me 2 extra accent inserts (it was a small line/logo, much smaller than the whole inner plate)
But now I have a black, red, and purple. For whatever keyset I end up choosing!
Offline beerafffe1
« Reply #36 on: Mon, 07 May 2018, 13:24:40 »
I echo the last few comments, if there was an option to get additional inserts I would join in on this.
Offline kennardsmith
« Reply #37 on: Mon, 07 May 2018, 16:47:23 »
Does the PCB support split backspace?
[Control] is just left side of [A]. It comes from Sun Type3 key layout.
« Reply #38 on: Mon, 07 May 2018, 17:02:05 »
Looks like 1 fixed layout. I would also prefer split backspace.
« Reply #39 on: Mon, 07 May 2018, 17:12:49 »
i'd be willing to "adjust" the plate with a file (or even get a custom laser cut plate) …so long as the PCB supports it.
Offline nathanchere
« Reply #40 on: Mon, 07 May 2018, 20:09:20 »
Way too expensive for a closed-source board, plus I don't want to support the kind of douchebaggery that profits off open source projects and keeps their own code closed for no good reason.
Offline xondat
  • i'm not a star
« Reply #41 on: Mon, 07 May 2018, 20:12:45 »
Closed source board meaning the design or the firmware?
Offline lecorsair
« Reply #42 on: Mon, 07 May 2018, 23:32:39 »
I'm guessing it's in reference to papa's post.
Re: [GB] ALF X3 Renova GB ENDED
« Reply #43 on: Wed, 09 May 2018, 05:33:23 »
Same situation as the cod67. Just as worrying the programming website has a cart feature.
Offline Starius
« Reply #44 on: Wed, 09 May 2018, 07:06:47 »
They've all been sold, folks.
Now us lucky (and perhaps more financially strapped) few play the waiting game!
Offline trikoi00
  • GMK bias
« Reply #45 on: Sat, 12 May 2018, 22:57:03 »
Looking for someone to take my spot of White/purple with brass insert order. Pm me.
Offline trikoi00
  • GMK bias
« Reply #46 on: Tue, 29 May 2018, 07:07:29 »
jjm5812, kindly pm me at u/trikoi00 on reddit. I have problem using messages in GH. I have news from zfrontier.
« Reply #47 on: Fri, 29 June 2018, 14:26:11 »
Looking to get rid of my spot, white/purple kit. PM if interested.
Offline vewy_nice
« Reply #48 on: Sun, 12 August 2018, 14:10:43 »
I've been typing on another board with southpaw-style F-keys recently, and realized that... I can't freakin' type on this layout!
(I learned to type a weird way, and home my fingers on the left side of the keyboard)
If someone wants my spot... Like the couple above me, white and purple.
If not, hey it's pretty to look at, it wouldn't be my first.
we could even wait till I get it, and I can ship it to 'ya. Whatever works, idk.
Offline Poesjuh
« Reply #49 on: Mon, 13 August 2018, 10:26:15 »
Hah I can relate to that. I have a revo kmini that has the same layout and happens plenty of times that I misplace my left hand :p
Sent from my iPad using Tapatalk
