Author Topic: For the Cherry MY switch lovers  (Read 4900 times)
Offline iMav
  • geekhack creator/founder
Offline Nonmouse
« Reply #1 on: Thu, 15 April 2010, 06:29:09 »
If they were HANUS (anus, henh-henh [/Beavis]), they'd be worth harvesting the caps.  I suppose even the laser caps might be worth it for someone wanting white caps...
[/color]
Offline itlnstln
« Reply #2 on: Thu, 15 April 2010, 07:47:28 »
Would you be able to stick the guts of a G80-3000 into one of these cases?  It might be good mod fodder.
Offline didjamatic
« Reply #3 on: Thu, 15 April 2010, 08:02:04 »
Great deals for a long lasting keyboard.  When you consider what businesses pay for a replacement board and what they get, these Cherrys are a bargain.
Offline Mental Hobbit
« Reply #4 on: Thu, 15 April 2010, 09:06:57 »
Quote from: itlnstln;172388
Yep, it's the same case. Swapping guts takes less than a minute without any tools.
Typing on blues.
Offline itlnstln
« Reply #5 on: Thu, 15 April 2010, 09:08:51 »
Awesome.  I like the white better than the black, especially since it has all-white keys.  The  cap swap will take awhile, though.
Offline keyb_gr
  • Cherrified user
    • My keyboard page (German)
« Reply #6 on: Thu, 15 April 2010, 09:34:50 »
Quote from: Mental Hobbit;172403
Not with the "new-style" 3000 cases as pictured here. First of all the clips are a bit of a pain to open, and then there are a few screws inside as well. I would assume the guts of contemporary German-made G80-3000s would swap right in (there were some internal G80/G81 differences with the old-style 3000 cases though), but see little reason to do that.
« Reply #7 on: Thu, 15 April 2010, 09:41:52 »
Dye cases in all colors and swap daily/monthly/by mood/season?
Typing on blues.
« Reply #8 on: Thu, 15 April 2010, 10:02:59 »
Use a sharpie then ;P
Typing on blues.
Offline keyb_gr
  • Cherrified user
« Reply #9 on: Thu, 15 April 2010, 17:56:10 »
man Thermometer
Offline itlnstln
« Reply #10 on: Fri, 16 April 2010, 06:51:41 »
I'm bidding on the 3-board listing, but if someone else wins, would they mind selling me one of the 'boards (from either listing)?  I just want one (NIB) 'board to mod my 3000 to white.  Thanks!
Offline sixty
    • http://deskthority.net
« Reply #11 on: Sat, 17 April 2010, 02:55:01 »
Btw, these are probably new generation keyboards. That means the keys will be thin PBT and not all keys will be MX compatible. With the new style G81-3000s at least backspace, enter, both shifts, spacebar, numpad 0, numpad +, numpad enter and all of the front row keys will not be MX compatible.
Offline Rajagra
« Reply #12 on: Sat, 17 April 2010, 07:46:19 »
Quote from: ripster;172421
ABS cases.  Warp problems when dyeing.
Skip warp. Go straight to ... LUDICROUS SPEED!
Offline HaaTa
  • Master Kiibohd Hunter
  • Kiibohds!
    • http://kiibohd.com
« Reply #13 on: Sat, 17 April 2010, 08:18:04 »
Nah nothing beats the speed of LINT!
*Damn, something that's not on youtube*
Kiibohd
ALWAYS looking for cool and interesting switches
I take requests for making keyboard converters (i.e. *old keyboard* to USB).
Offline sixty
« Reply #14 on: Sun, 18 April 2010, 01:50:12 »
Quote from: ripster;172981
You mean MX compatible or they can't be swapped with Filco/DAS?    Are they offcenter or something?
Yeah, they can't be swapped with Filco/DAS nor other Cherry MX boards. I had to search for a long time to find one G81 in the house, because I burned all of mine with fire, but here you go:
Offline itlnstln
« Reply #15 on: Thu, 22 April 2010, 07:19:44 »
Did anyone win one of these auctions?  If so, could you spare one of these 'boards for me?
Offline ricercar
  • mostly abides
« Reply #16 on: Thu, 22 April 2010, 12:36:06 »
I find that the MY caps with legs work acceptably on MX switches after I clip off the legs. Even without stabilizers, they seem to work on off center hits.
