Author Topic: Squeaky Spacebar Fix?  (Read 4052 times)
Offline Snuffalo Bill
« on: Sat, 12 May 2018, 01:42:14 »
This is my first post on this forum, but I have lurked for a little while.
I own a Magicforce 68 with Gateron browns. Its a great little keyboard, but since I've had it (purchased new) the spacebar has squeaked. This only happens when I push hard on the left side of the spacebar. I suspect it has something to do with stabilizer. Any suggestions? If all it needs is some lube, is there a specific brand that you all would recommend? Thanks.
Offline ag36
Re: Squeaky Spacebar Fix?
« Reply #1 on: Sat, 12 May 2018, 09:06:39 »
Can you take the spacebar off and take a picture? Do you have key puller? Often it's because stabilizers was misaligned not because not lubed, cheapest solution is silicone grease or lithium grease.
http://www.wasdkeyboards.com/index.php/products/keyboard-parts/super-lube-silicone-lubricating-grease-with-ptfe.html
https://www.amazon.com/Danco-88693-Silicone-Grease/dp/B000DZFUPC/ref=sr_1_3?ie=UTF8&qid=1526134074&sr=8-3&keywords=silicone+grease
« Last Edit: Sat, 12 May 2018, 09:08:27 by ag36 »
Model M*5, SSK*4, M13 black*1, Model F XT*1, AT*1 F107*1, Unicomp*1, 3278 *1, Leopold FC750R*2, 980M*2 FC980C*1 Filco majestouch 2 TKL*1, Cooler Master MasterKeys S PBT*1, Uniqey Q100*2, Ducky pocket*1, KBD75*2, KBD19X*2, HHKB pro 2*1, Type-S*1 Topre Realforce RGB*1, 108 all 30g*1, numpad*1, 87U*1 Dell AT101W*2, Alps64*2, V80 matias quiet click*2, Quiet liner *1, WYSE ASCII *1
