Author Topic: [IC]SA 2600 Keycaps (GB open, Maxkey)  (Read 75249 times)
Offline trabbit
Re: [IC] MAXKEY SA 2600 Keycaps
« Reply #50 on: Thu, 31 May 2018, 22:05:00 »
I'm sorry this feels way to similar to GMK Iris, with different novelties and an every-so-slightly lighter tone. I do love my Iris, maybe a courtesy contact with Iris' designer for a similar colorway but different novelties and profile?
Obviously,it's a different color set.
Offline York Chan
« Reply #51 on: Thu, 31 May 2018, 22:15:21 »
Of course, it's completely different in terms of novelty keys,and color are also different
Offline goodman247
  • It's confirmed, I'm an idiot.
« Reply #52 on: Thu, 31 May 2018, 23:17:07 »
This looks very cool, and the novelties looks great!! Voted and hopefully this set becomes reality!!
Offline York Chan
« Reply #53 on: Fri, 01 June 2018, 01:17:03 »
Thank u man,I hope so :thumb:
Offline trabbit
Re: [IC] MAXKEY SA 2600 Keycaps (Update on 4th Jun)
« Reply #54 on: Tue, 05 June 2018, 23:36:46 »
When will the GB start?
Offline York Chan
« Reply #55 on: Wed, 06 June 2018, 01:08:09 »
This has not been decided yet, please wait patiently
Offline kyoumau
Re: [IC]SA 2600 Keycaps (Update on 4th Jun)
« Reply #56 on: Sat, 09 June 2018, 11:41:05 »
The colorway is beatufil and the novelties too.
I'm interested in r1 1u novelties.
Offline Duckunderscore
« Reply #57 on: Sat, 09 June 2018, 22:08:22 »
voted for it on MD, not huge on SA but this colorway might just change that
Offline lollipoplouie
« Reply #58 on: Sun, 10 June 2018, 04:44:21 »
I recently got a Max Keys dolch set and absolutely love the caps! I am definitely interested and glad you're deciding to go with Max Keys. The colors and novelties look great!
Sent from my SAMSUNG-SM-G890A using Tapatalk
Offline York Chan
« Reply #59 on: Sun, 10 June 2018, 20:59:42 »
Honestly, does the r1 1u novelties key a bad input experience?
I'm thinking about this...
Offline kyoumau
« Reply #60 on: Sun, 10 June 2018, 21:33:17 »
I didn't understand the question, can you reformulate it?
If the price of the keyset get too high because of the r1 novelties, I guess I can live without them and get a little more affordable price for the set.
Offline York Chan
« Reply #61 on: Mon, 11 June 2018, 02:25:22 »
I mean, it's easy to get the wrong input if you use the Numbers R1.
Offline York Chan
« Reply #62 on: Mon, 11 June 2018, 02:27:11 »
Thank u for your like~ :thumb:
Offline York Chan
« Reply #63 on: Mon, 11 June 2018, 02:29:04 »
This is just for one reference. Thank you for your interest~ :thumb:
Offline ProtonDecay
« Reply #64 on: Wed, 20 June 2018, 15:52:12 »
Even if I don't go with the base set, I'm in for 1 to 5 (depending on price) sets of those novelties.
Any chance you can split the novelties from the spacebars?
Have I mentioned that I LOVE those novelties?
Offline York Chan
Re: [IC]SA 2600 Keycaps (Update on 21th Jun,Add some keyboards renders)
« Reply #65 on: Fri, 22 June 2018, 02:42:36 »
The sales method has not been decided yet, but my idea is the same as yours :thumb:
Offline beekey
« Reply #66 on: Fri, 22 June 2018, 04:20:17 »
Is it possible to have something like the spacebars/keys set a lot of SP sets have?
Example from SA Green Screen.
I love split space bar layout which makes use of the 2.25 and 2.75 blanks. Would love to see something like this for Maxkey sets.
Offline York Chan
« Reply #67 on: Thu, 28 June 2018, 20:57:53 »
Thank you for your suggestion. I'll consider it as appropriate :thumb:
Offline lizardsticks
Re: [IC]SA 2600 Keycaps (Update on 27th Jun,new layout for SP)
« Reply #68 on: Thu, 05 July 2018, 11:00:01 »
So with it being SP now, are there any chances for an Ergo kit? Really liking these colors but I'm trying to hunt for a SA Ergo Kit that I would like so that's the only way I'd be in.
Offline York Chan
« Reply #69 on: Mon, 09 July 2018, 04:56:20 »
I will add ergo to this keycap set :thumb:
Offline thedog4
« Reply #70 on: Mon, 09 July 2018, 04:59:48 »
Love the colors of the set and would definitely be interested in getting it! its very retro-like. I still would prefer Maxkey over SP, especially since it means cheaper prices and a much shorter lead time.
« Reply #71 on: Mon, 09 July 2018, 08:52:44 »
You the best  :D
Offline York Chan
« Reply #72 on: Tue, 10 July 2018, 01:40:56 »
I am negotiating with both sides at the same time, thank you for your support! :thumb:
Offline York Chan
« Reply #73 on: Tue, 10 July 2018, 09:44:53 »
199781-0
« Last Edit: Tue, 10 July 2018, 21:17:15 by York Chan »
Offline poolside
Interested in this set. Loud colors and nice novelties  :thumb:
Offline York Chan
Thank u very much~~ :thumb:
Offline Max_P0
A bit of a noob question, will this be manufactured by Signature Plastic ?
Offline York Chan
Offline Rubbermilitia
Re: [IC]SA 2600 Keycaps (Update on 15th Jul,Add Ergo kits)
« Reply #78 on: Thu, 19 July 2018, 09:07:37 »
In for the novelties, maybe also space bars
Offline York Chan
« Reply #79 on: Tue, 24 July 2018, 01:07:53 »
Thx, bro ;D
Offline Zilleon
« Reply #80 on: Tue, 24 July 2018, 17:33:57 »
Any plans to add Colemak support?
If so I'm in :)
Offline York Chan
« Reply #81 on: Wed, 25 July 2018, 20:44:03 »
If so I'm in :)
I'm sorry, we have no plans to add Colemak at present.
Offline taropaste
« Reply #82 on: Thu, 26 July 2018, 13:11:06 »
I love the colors. Nice work!  :thumb:
« Reply #83 on: Thu, 26 July 2018, 13:13:38 »
Fantastic. Ergo kits are in. Looks great!
Offline York Chan
« Reply #84 on: Thu, 26 July 2018, 20:57:25 »
Thank u for your interest~
Offline Macflag
« Reply #85 on: Fri, 10 August 2018, 16:22:23 »
Looks great! Any cost estimate?
Offline otanishock
  • One of the cool kids :>
  • ファーストラブ
« Reply #86 on: Fri, 10 August 2018, 16:32:28 »
Planning on a drop soon?
Offline York Chan
« Reply #87 on: Wed, 15 August 2018, 05:04:29 »
The cost has not been finalized.
Thanks for support~ :D
Offline York Chan
« Reply #88 on: Wed, 15 August 2018, 05:07:01 »
Within two months.
Offline oldcat
  • 65% is Life
« Reply #89 on: Wed, 15 August 2018, 07:24:58 »
What can I say? All in!
Offline York Chan
« Reply #90 on: Thu, 16 August 2018, 01:42:35 »
dalao,niubi :thumb:
Offline lovetree
Offline Bigaku
  • コンニチハワタシノナマエハビガクデス Hello my name is Bigaku or ビガク
« Reply #92 on: Sun, 19 August 2018, 14:56:37 »
Can I get a price estimate? Also this colorway looks amazing  I'll definitely join! :thumb:
HHKB Pro 2 With GMK Space Cadet
Colorways I'm supporting
Offline oldcat
  • 65% is Life
« Reply #93 on: Sun, 19 August 2018, 15:31:11 »
Please work on this! Plan to all in
Offline Harms
« Reply #94 on: Sun, 19 August 2018, 17:56:49 »
Ergo support, but no ortho support? :(
Sent from my STV100-3 using Tapatalk
Offline York Chan
« Reply #95 on: Mon, 20 August 2018, 05:11:49 »
None at the moment.
I will update if there is~ :thumb:
Offline York Chan
« Reply #96 on: Mon, 20 August 2018, 05:14:01 »
Sorry~
Do you have any sample?
Offline Harms
« Reply #97 on: Mon, 20 August 2018, 14:39:43 »
Sorry~
Offline York Chan
« Reply #98 on: Mon, 27 August 2018, 03:41:44 »
Sorry~
I'll take it into consideration, thank you~
« Reply #99 on: Fri, 07 September 2018, 03:03:27 »
Any update on this? Love this set, definitely in for TKL, numpad, and novelties.
